Fired up after a long sleep. Sounded good, then...
#2369623
09/12/17 08:10 PM
09/12/17 08:10 PM
Posts: 12,807 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
What's the prime culprit? Oil filter didn't fly off. Any most likely connection?
p.s. did not need this today...not that there's ever a good time.
Trying to enjoy life!
Re: Fired up after a long sleep. Sounded good, then...
[Re: calmopar]
#2369634
09/12/17 08:18 PM
09/12/17 08:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looks like oil
hole in pan
[Re: calmopar]
#2369654
09/12/17 08:41 PM
09/12/17 08:41 PM
calmopar
East Bay, N. Cal.
Oil. Fired up, purred like a kitten for 60 seconds, then some secondary noise made me think "uh oh" then oil light on. I immediately shut it down and went around front and the car was bleeding out oil.
[Re: calmopar]
#2369741
09/12/17 11:14 PM
09/12/17 11:14 PM
calmopar
East Bay, N. Cal.
Oil filter was super loose. Guess I should have checked before I fired it up. Hand-tightened, will fill up with oil and try again. Or should I get a wrench?
[Re: calmopar]
#2369801
09/13/17 12:26 AM
09/13/17 12:26 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Oil filter was super loose. Guess I should have checked before I fired it up. Hand-tightened, will fill up with oil and try again. Or should I get a wrench? No wrench. You might want to spin on a new one.
[Re: calmopar]
#2369865
09/13/17 02:10 AM
09/13/17 02:10 AM
calmopar
East Bay, N. Cal.
Thanks, ok I will get a new filter and hand tighten it, fill with oil, then fire it up again. Now I have to figure out how to get all that oil out of my engine compartment. yuck! do people still steam clean and is that advisable?
[Re: calmopar]
#2369884
09/13/17 04:03 AM
09/13/17 04:03 AM
Posts: 43,317 Bend,OR USA
Cab_Burge
Go buy several cans of engine degreaser and use it several different times after rinsing off the first batch ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Not the foaming type either ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) : ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: calmopar]
#2369895
09/13/17 05:49 AM
09/13/17 05:49 AM
Morty426
Sacramento CA
Thanks, ok I will get a new filter and hand tighten it, fill with oil, then fire it up again. Now I have to figure out how to get all that oil out of my engine compartment. yuck! do people still steam clean and is that advisable? Go buy some Gunk at the auto parts store. Don't spray anything electrical with it.
[Re: calmopar]
#2370039
09/13/17 01:46 PM
09/13/17 01:46 PM
Supercuda
About to go away
About to go away
up yours
Anyone bother to read the directions when putting on a new filter?
Wix:
Spin on the new filter. When the gasket contacts the mounting base, rotate the filter 3/4 turn.
Fram:
Screw new filter on until gasket reaches base contact. Then tighten according to instructions on filter using tightening guide markers.
Cummins:
Carefully read the installation instructions printed on the outside of the filter to determine the number of turns the filter must to be rotated past gasket contact for proper installation and gasket compression.
Purolator:
Tighten the amount specified for your filter beyond gasket contact (3/4, ¾ - 1, etc)
They all also state use CLEAN oil and not grease.
[Re: calmopar]
#2370064
09/13/17 02:16 PM
09/13/17 02:16 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
Never had a spin-on oil filter drip a drop when its been hand tightened. Of course you have to be smarter than the filter and make sure it and your hands are clean so you can get a solid grip. (Did I really need to say that?)
Yes, the "standard" is film of new oil on the gasket and tighten 3/4 turn once the gasket makes contact. For a new filter.
Filter wrenches can distort and puncture the filter case.
[Re: nomore65BelvJim]
#2370108
09/13/17 03:21 PM
09/13/17 03:21 PM
Challenger 1
Cincinnati, Ohio
It don't sound like you have ever done a big truck oil change, it is impossible to get those big filters tight by hand. In 33 years of doing it here at work, I have yet to damage a filter big or small by using filter wrench on them.
