Is 68-70 B body roof structure all the same? #2369662
09/12/17 08:56 PM
09/12/17 08:56 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I've got a 68 Charger that needs some roof structure and quarter panel structure. I've also got a 70 coronet parts car with clean structure. I know the roof skins are different for the 68-70 charger compared to all the other 68-70 b bodies but I'm assuming the roof structure is the same for all 68-70 b bodies. Am I wrong? Ideally I'd use the roof and quarter panel structure (not the skins) from the 70 coronet to repair the 68 Charger. Thanks in advance.
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Is 68-70 B body roof structure all the same? [Re: 70B5Cuda] #2369815
09/13/17 12:43 AM
09/13/17 12:43 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe the Charger requires Charger parts, at least in the roof, and probably the quarter as well. The roof and how it attaches to the quarter is pretty radically different then the other B body cars, I can't believe anything under the sheet metal would be correctly located, but I suppose that would depend on how deep into the structure you need to replace. Gene
