How much is a tenth in ET worth to you? #236904
02/26/09 01:53 PM
02/26/09 01:53 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
How much are you willing to lay out for each extra tenth off your ET? If it cost you $1K to switch to a roller from a solid cam and you get .2, is it worth $500 / tenth? If you put on a set of CNC heads that get you another .3, is it worth $1000 / tenth? Where do you draw the line?
Re: How much is a tenth in ET worth to you? [Re: PorkyPig] #236905
02/26/09 01:56 PM
02/26/09 01:56 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Depends who is in the other lane.Seems sometime I would pay anything
Re: How much is a tenth in ET worth to you? [Re: scatpacktom] #236906
02/26/09 01:59 PM
02/26/09 01:59 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I'm just a bracket racer but I love chasing e.t. and getting as much out of my car as possible. If I was to pick up a tenth I'd run a 5.96 in the 1/8th and that would be sweet. I'd spend $500 for that easy.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: How much is a tenth in ET worth to you? [Re: PorkyPig] #236907
02/26/09 02:09 PM
02/26/09 02:09 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I put out about 50 grand for 2 tenths but still hoping for another tenth or so-and still spending.
Re: How much is a tenth in ET worth to you? [Re: BobR] #236908
02/26/09 02:14 PM
02/26/09 02:14 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Maybe I shuold ask how fast are you going and how much are you willing to spend to go a tenth faster.
Re: How much is a tenth in ET worth to you? [Re: PorkyPig] #236909
02/26/09 02:45 PM
02/26/09 02:45 PM
Chicagoland
chargerron69 Offline
Chicagoland
it kinda depends on what tenth it is ie. 10.8 to 10.7 not a whole lot but 10.0 to 9.90 yes
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: How much is a tenth in ET worth to you? [Re: Jacob Pitt] #236910
02/26/09 03:02 PM
02/26/09 03:02 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
I'm in the same boat as you...Would be nice to get that 5 second slip...
Curtis
Taking over the World one win light at a time.
Re: How much is a tenth in ET worth to you? [Re: chargerron69] #236911
02/26/09 03:03 PM
02/26/09 03:03 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Cost Vs ET gain is directly proportional to the current e/t your running.
The faster one goes for every tenth gained, the next tenth gets more difficult.
I tried my best to pick up a few tenth in the dragster I ran but picking up 4-5+ mph at that rate takes well over 100hp to see these gains. Not easily accomplished, by even cam changes etc, especially when your already running max effort stuff. Im sorry, switching carbs, intakes,headers,cams, timing changes, tuning stuff. Not one single thing alone would get you the gain needed. More than likely all the things needed to see good e/t gains. So in my case several thousand dollars would may or may not see some return at the strip.
Where as uncapping the headers, jetting, timing changes could net 1/2 second e/t going much slower, dollars spent..maybe zero.
Re: How much is a tenth in ET worth to you? [Re: Bob_Coomer] #236912
02/26/09 03:21 PM
02/26/09 03:21 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I spent 20k for 1 sec to go from 9.90 to 8.90. That's about 2k per .1
Re: How much is a tenth in ET worth to you? [Re: PorkyPig] #236913
02/26/09 03:35 PM
02/26/09 03:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I dont think its allways a money thing , Ive seen lots of low dollar 8k engines run faster than 20k riggs , Just depends on who is wrenchen on them
Re: How much is a tenth in ET worth to you? [Re: emarine01] #236914
02/26/09 05:48 PM
02/26/09 05:48 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
We'll see!
Re: How much is a tenth in ET worth to you? [Re: RAT PATROL] #236915
02/26/09 06:29 PM
02/26/09 06:29 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
We'll see!
X2 here
Hint it was more than $500
Re: How much is a tenth in ET worth to you? [Re: PorkyPig] #236916
02/26/09 06:34 PM
02/26/09 06:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think backwards... I always think, make it lighter,
cost less in most cases and is usually easier on parts
Re: How much is a tenth in ET worth to you? [Re: Wv68charger] #236917
02/26/09 06:44 PM
02/26/09 06:44 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
For my Cutlass going from a 16.7 @ 80mph (bone stock 2bbl 350, with 170K miles). The new mill is running about $800 total
I'll let you know this season
Re: How much is a tenth in ET worth to you? [Re: MR_P_BODY] #236918
02/26/09 06:46 PM
02/26/09 06:46 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
It's too bad the cost to gain ratio isn't linear. A tenth to me is worth whatever I can divert from other expenses. Which brings to mind the absolute cost saving miracle of nitrous. There's nothing that will buy a tenth faster, easier, or cheaper on almost any application. I'm an N/A guy now, but if I had to have a tenth that would be it.
Re: How much is a tenth in ET worth to you? [Re: PorkyPig] #236919
02/26/09 07:07 PM
02/26/09 07:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Well, I just spent $900.00 and picked up a tenth over my previous best but, I know I`ll see a bit more. I know guys who have spent $4,000-$5,000 on transmissions to get a couple.
Re: How much is a tenth in ET worth to you? [Re: Thumperdart] #236920
02/26/09 07:14 PM
02/26/09 07:14 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
as much as i got,witch right now aint much,my last investment netted me 6 tenth,s and ended up at 1,000.00 bucks a tenth.
Re: How much is a tenth in ET worth to you? [Re: Thumperdart] #236921
02/26/09 07:14 PM
02/26/09 07:14 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
In my case ,a tenth would do nothing for me. 10.80's right now. I need a cage, belts, and some other small things to be "legal" No more racing. Easy tenths include , but not limited to ..
#1 less weight
2 balancing of engine
3 trans efficiency
4 headwork
5 carb efficiency
6 proper gearing
7 proper tires
8 proper suspension tuning
9 proper intake/head/carb matching
10 efficienct driving
11 FireCore50 Ignition Wires
There are a lot more , in-depth things, but I think these are all important.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: How much is a tenth in ET worth to you? [Re: sunroofgtx] #236922
02/26/09 08:57 PM
02/26/09 08:57 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I'll second this. Hey, they got me my 12.
Heck, the cheapest tenth I ever got was bolting on a carb spacer that I already had. Though it's pretty easy to pick up ET when you are as slow as me. lol...
Re: How much is a tenth in ET worth to you? [Re: dustergirl340] #236923
02/26/09 09:07 PM
02/26/09 09:07 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
when you say a tenth, are we talking 1/4mi. or 1/8mi. believe it's a lot easier to gain a tenth in the 1/4. don't think i'm a jerk, but it's a lot cheaper to get that tenth with your brain than with your wallet
