I would ask about Summits return policy if there is an issue or defect
I've had a recent issue with them.
Not their fault either.
I ordered a pair of wheels and they came with the wrong bolt pattern.
The box said it was right, but the wheels were not.
I had tires mounted with out checking the wheels.
The invoice on the box read,
"Attention, before mounting any tires make sure the wheels fit the car. If you mount them you own them."I did not even read the invoice until after the fact.
My wheels came with the wrong bolt pattern.
Summit is taking them back anyway and sending the correct wheels.
The wheels came from Crager so Summit had no control on what was shipped. They are still making things right for me. They did not have to. Top notch outfit.
