Do I need an adaptor for Edelbrock / Holley to Offenhauser #2368098
09/10/17 12:08 AM
09/10/17 12:08 AM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I have an Offenhauser 360 manifold on my 440, and it does not have 4 holes in it ,but rather a square hole with a divider running down the middle... and a big notch in the last 1/4 of the divider. I can't post a pic right now, but...can I run any old carb gasket on it for Holley vacuum seondary or Edlebrock Performer carb? Or do you recommend a particular carb gasket and/or spacer? I have a 70'challenger bulge hood with not a lot of clearance with stock dual snorkel.
Re: Do I need an adaptor for Edelbrock / Holley to Offenhauser [Re: Moparmaniacc] #2368107
09/10/17 12:25 AM
09/10/17 12:25 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I had that same manifold on my big block for a while and I ran this gasket. A little thicker than some. Helped keep heat out of the carb IMO..
https://www.summitracing.com/parts/edl-9...ASABEgKTl_D_BwE
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Do I need an adaptor for Edelbrock / Holley to Offenhauser [Re: wingman] #2368232
09/10/17 11:36 AM
09/10/17 11:36 AM
Wingmans' pic appears to match the manifold descrip so that would be my choice (all of the gasket is supported by the manifold).
