trans cooler #236778
02/26/09 12:11 PM
02/26/09 12:11 PM
Sac, CA
mopowers Online confused OP
mopowers  Online Confused OP
Sac, CA
What trans cooler would you all recommend for a street/strip car?
I've noticed there are a couple different designs out there. Which one cools better?
or
Re: trans cooler [Re: mopowers] #236779
02/26/09 12:33 PM
02/26/09 12:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I use the bottom one , but with AN fittings and braided line.
Re: trans cooler [Re: Quicktree] #236780
02/26/09 12:45 PM
02/26/09 12:45 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I have always used the style shown in the bottom picture. I believe B&M sells the one you show in your top pic. I bet either would be fine.
Re: trans cooler [Re: cl440] #236781
02/26/09 12:59 PM
02/26/09 12:59 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I am using the plate styl like the top one
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: trans cooler [Re: dusturbd340W5] #236782
02/26/09 01:38 PM
02/26/09 01:38 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Evan...I use the top one on all cars I've ever built I have had a few issues with the bottom style.Also the top one will fit real nice with the frame work for your radiator support like mine.If your coming to the March Meet look me up again so you can steal my mounting of that cooler too.....LOL
Re: trans cooler [Re: Chassisman] #236783
02/26/09 01:46 PM
02/26/09 01:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the top unit is a multi pass cooler, that means zero restriction. the bottom unit drops the pressure at each 180* bend the fluid has to go around. the top unit is high performance, the bottom unit isn't. i used to make coolers like to bottom unit & when cold that bottom unit would creat a 30 psi restriction on oil flow.
Re: trans cooler [Re: rebel] #236784
02/26/09 01:52 PM
02/26/09 01:52 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
The top one.
Re: trans cooler [Re: Chassisman] #236785
02/26/09 01:58 PM
02/26/09 01:58 PM
Sac, CA
Sac, CA
I want to emphasize that the car will see a lot of street time, so I want the best cooling I can get. The whole pressure drop thing is new to me. I didn't realize that. Maybe the top plate style is the way to go. I'll just get the biggest one they make.
Ron, I don't know what you're talking about. I'm just borrowing some ideas. Wait till you see my fan set-up. BTW, we'll definitely stop by your camp again at the MM.
Re: trans cooler [Re: mopowers] #236786
02/26/09 02:04 PM
02/26/09 02:04 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
TOP one,,,,
I think mine is a B and M Supercooler,,,looks identical.
69 Charger 496 Stroker,,,,,solid cam, E heads,,,STREET driven,,,no issues........
Re: trans cooler [Re: mopowers] #236787
02/26/09 02:05 PM
02/26/09 02:05 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Just look for the American flag and Pirate flag again....that and the empty rum bottles strewn about.Friday night we're throwing a BBQ for 200 or so plus drive-in lawn chair movie on the big screen...and of course fireworks.. ...so by sat. we'll be REALLY shot.....LOL
