Rear axle?? Bolt in axle to roll around?? #2367707
09/09/17 12:39 AM
09/09/17 12:39 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
I would like to bolt the axles in my Demon and roll it around in the shop (not a lot) without the center section in it.
I have aftermarket axles, and the green bearings on them.
Car is completely bare, just coming out of the paint shop.
I have heard it's not good from some, ok from others.
Now I'm looking to the professionals.
As always, thank you in advance!!
Wally.
Re: Rear axle?? Bolt in axle to roll around?? [Re: wkroncke17] #2367711
09/09/17 12:43 AM
09/09/17 12:43 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just put a piece of pipe in the center section to slip over the axles. It will keep them from wobbling a lot. Make it long enough to go about 5" on each axle.
Re: Rear axle?? Bolt in axle to roll around?? [Re: stumpy] #2367734
09/09/17 01:37 AM
09/09/17 01:37 AM
iagree My 1965 Dart is that way now with a narrowed Dana 60 and 35 spline axles up
