383 head swap #236681
02/26/09 11:23 AM
02/26/09 11:23 AM
S Williamsport
therick Offline OP
therick  Offline OP
S Williamsport
I have a 1971 383 2brl. I want a little more out of it.Is it worth swapping the heads for a set of 916's that I have. How much more compression do you think it will give me? I plan on using this cam (Advertised Duration 272/ 282, Lift .442/ .465). auto with a 2800 stall converter and 4:10 gears. Car is 3500 lbs.
Re: 383 head swap [Re: therick] #236682
02/26/09 11:31 AM
02/26/09 11:31 AM
906's or 915's
Re: 383 head swap [Re: therick] #236683
02/26/09 11:50 AM
02/26/09 11:50 AM
Central NC
gch Offline
gch  Offline
Central NC
If you switch to a set of 915 or 516 closed chamber heads it will likely give you a .5 increase in compression.If you are going to swap them maybe mill them enough to get it up to 9.5=1.That will work really well with the cam you have picked.
If you use the 516 heads enlarge the exhaust valve to your 1.74 stock size.
If you have a 906 head it will give you no increase at all.
