340 Aluminum Intake Preference #2366712
09/06/17 11:58 PM
09/06/17 11:58 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
I just put a 340 in my sons 71 Scamp. 555 lift cam .030 10.5:1 Ported 69 X-Heads,Holley 600 (for now), automatic, 323 sure grip street car. I broke a piece out of the LD4B intake while removing the temp sensor. Im going to get it repaired but wondering if it would benefit me a lot to go with a different intake. I read that the LD4B is better on a 273 or 318. I have a chance to trade for a Weind Stealth. Are there any thoughts on the Stealth? I can buy a used Edelbrock Air Gap at a decent price to. Any experience will be appreciated. Thanks
All MOPARS & nothig else.
Re: 340 Aluminum Intake Preference [Re: Budman] #2366717
09/07/17 12:07 AM
09/07/17 12:07 AM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
If it were mine, I would use the Air Gap intake, I think older Edelbrock
would hamper the performance, especially with the cam you are using. What heads/carb. are you using Is this a street car or track car?
Re: 340 Aluminum Intake Preference [Re: Budman] #2366720
09/07/17 12:09 AM
09/07/17 12:09 AM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
street car
Re: 340 Aluminum Intake Preference [Re: Budman] #2366724
09/07/17 12:15 AM
09/07/17 12:15 AM
VA
demons r us Offline
demons r us  Offline
VA
I would go with the air gap. Good intakes and you can get a deal on one.
win win
Re: 340 Aluminum Intake Preference [Re: RoadRunnerLuva] #2366734
09/07/17 12:36 AM
09/07/17 12:36 AM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Ported X-Heads and Holley 600 (for now). will upgrade the carb if needed
Re: 340 Aluminum Intake Preference [Re: Budman] #2366745
09/07/17 12:54 AM
09/07/17 12:54 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Used edelbrock RPM or Air Gap.
Not a big performance difference in this two. Same for the overpriced LD340. But the air gap gets the attention cause it's the "new thing".
Re: 340 Aluminum Intake Preference [Re: Budman] #2366755
09/07/17 01:09 AM
09/07/17 01:09 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
That LD4B has small ports and runners. Not a good physical match up with those heads. A Performer intake is slightly better than the stock and weights less. With a 1/2- 1" spacer that intake wakes up. Don't remember the # but the one that fits the 360 will work.
Re: 340 Aluminum Intake Preference [Re: Budman] #2366759
09/07/17 01:17 AM
09/07/17 01:17 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The Weiand may be a little tall for the Scamp's hood depending on the aircleaner.
My notes are the average pad height on the 8007 & 8022 is 5.41"
The LD340 is 5.12"
The Performer RPM is around 5.35
My opinion is the the LD4B is probably better for street than the LD340. If you stick with the LD4B after repairs, you could open up the ports a little to match the heads. I think the runners are smaller than the LD340 and will keep the velocity up better. The RPM's runners are definately smaller cross section. I have both the LD340 and the RPM but have not yet had a chance to try out the RPM. So like everyone else, its all theory, no back to back!
Re: 340 Aluminum Intake Preference [Re: Budman] #2366768
09/07/17 01:33 AM
09/07/17 01:33 AM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
Im thinking that I should go with the Air Gap on the 340 Scamp and use the LD4B on my 318 Challenger.
Re: 340 Aluminum Intake Preference [Re: Budman] #2366789
09/07/17 02:25 AM
09/07/17 02:25 AM
GA
roadrunninMark Offline
GA
How does a Edelbrock TM5 compare? It is a single plane though.
Re: 340 Aluminum Intake Preference [Re: Budman] #2366859
09/07/17 11:03 AM
09/07/17 11:03 AM
New York
rarefish Offline
rarefish  Offline
New York
Over the years, I have always heard that the TM5 was not a good intake for the 340. Especially on a street driven 340.
Re: 340 Aluminum Intake Preference [Re: A/MP] #2366860
09/07/17 11:08 AM
09/07/17 11:08 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I don't think you are thinking about the Performer. It's not better than stock and there is exactly one Performer intake, there isn't another "that fits the 360". The Performer fits all the LA's and has port sizing a bit smaller than the stock 4bbl intake. Other than being lighter the stock intake is a better choice as is.
Don't be the exception.
Re: 340 Aluminum Intake Preference [Re: Budman] #2366882
09/07/17 11:53 AM
09/07/17 11:53 AM
I would do the trade & you'll be up & running in no time with virtually no cash outlay. I'm sure it has 360 ports & the dual plane will be what you need for your combo/app & your square bore carb will bolt right on. Keep It Simple Sam.
Re: 340 Aluminum Intake Preference [Re: Budman] #2367019
09/07/17 04:08 PM
09/07/17 04:08 PM
CA
crackedback Offline
crackedback  Offline
CA
With a 555 cam in it, I'd look for a RPM or Air Gap as they are easier to find and work very well.
There are a lot of unproven opinions about intakes out there for SB mopars. The best ones are the Performer 318/360 is not a good piece (if you have one, spend an hour with a grinder and put a 1" open spacer on it.). The LD4b is not right for a 340/360 head or an LD340 on a 318 port head is terrible.
These things live on for years...
Re: 340 Aluminum Intake Preference [Re: crackedback] #2367309
09/08/17 02:19 AM
09/08/17 02:19 AM
Planet Earth
Planet Earth
As I stated earlier, I would go with the Air-Gap with your combo, ditch
the 600 cfm (too small) and maybe try a 750 3310 Holley.
Plymouth Makes It!
Re: 340 Aluminum Intake Preference [Re: RoadRunnerLuva] #2367314
09/08/17 02:39 AM
09/08/17 02:39 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
On a street car the AirGap will help to keep the keep the air/ fuel charge cooler, and make consistant HP while driving.
If hood clearance is a issue use a drop air cleaner base.
Re: 340 Aluminum Intake Preference [Re: crackedback] #2367596
09/08/17 08:01 PM
09/08/17 08:01 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Wow! Someone with sense and truth!
Crackback, autoxcuda nailed it for you.
I like the 750 cfm idea.
Re: 340 Aluminum Intake Preference [Re: Budman] #2367912
09/09/17 02:27 PM
09/09/17 02:27 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I ran a Stealth on my 69 Valiant for a few years and it worked fine. Nearly the same front end sheetmetal as the 71 Scamp, and there are a number of ways to make it fit under the hood. I frequently used an old Moroso drop-base with a different lid, and I've used a factory-style unsilenced air cleaner with different height filter elements. The Stealth is pretty tall, but not crazy. It also came with ports at the gasket face that were small enough to work on a 318 head, but were easily opened up to 340 size. I gasket-matched mine to line up better with the later 360 heads.
Old pic, right after I got it back together:
I've got a Magnum M1 EFI intake on the car now, and the old unsilenced air cleaner JUUUUUUUST fits under the hood. I keep a big Sharpie pen in the car to touch up the little spot where it air cleaner rubs the brace under the hood...
Clair
