#2365657 - 09/05/17 07:23 AM Oil in the throttlebody
BigTerry Offline
Loc: Alexandria,La.
Hi guys
08 ram 5.7 I had replaced the tb last year i had carbon built up on it that have me concern.. I done a plug change on her and i pulled the pleumn off to see if i have the same issue .. well i had a oily built up on the blade again! Do i need to replace the intake gasket or is this normal for the hemi?
thanks guys for any help!
#2365814 - 09/05/17 12:59 PM Re: Oil in the throttlebody [Re: BigTerry]
HotRodDave Offline
Loc: Kalispell Mt.
the intake gasket only seals air except where the oil fil goes, I think you got a PCV problem.
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
#2366257 - 09/06/17 07:13 AM Re: Oil in the throttlebody [Re: HotRodDave]
BigTerry Offline
Loc: Alexandria,La.
i did't think about that! thank for head up on that!
#2384955 - 10/10/17 08:05 AM Re: Oil in the throttlebody [Re: BigTerry]
BigTerry Offline
Loc: Alexandria,La.
The pcv valve on his truck is werid it has a oring on it i guess this what fails? couldnt i just change the oring?
#2385828 - 10/11/17 05:31 PM Re: Oil in the throttlebody [Re: BigTerry]
outcast Offline
Loc: HellsGate
do a online check of oil catch can for dodge hemis . i think this well help you .
#2386134 - 10/12/17 07:10 AM Re: Oil in the throttlebody [Re: outcast]
BigTerry Offline
Loc: Alexandria,La.
oil catch can?
#2386143 - 10/12/17 07:40 AM Re: Oil in the throttlebody [Re: BigTerry]
BigTerry Offline
Loc: Alexandria,La.
what i seen and read was for 2009 and newer hemi will that work on a 08 hemi ram?
#2386388 - 10/12/17 03:37 PM Re: Oil in the throttlebody [Re: BigTerry]
outcast Offline
Loc: HellsGate
I would say yes as you seem to be having the same trouble as the newer hemis i have one on my 2014 6.1. it works . best of luck
#2395731 - 10/30/17 08:55 PM Re: Oil in the throttlebody [Re: BigTerry]
RealWing Offline
Loc: Ontario, Canada
I put a Billet Technologies PCV "Catch Can" on my 6.1 Hemi. So far I've collected 80 Ml of oil (1/3 cup) in 4000 miles. This is 80 ml of oil that did not get into my intake and deposit on my intake valves.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2015 BMW K1600 GTL
#2395791 - 10/30/17 10:17 PM Re: Oil in the throttlebody [Re: BigTerry]
Chargerfan68 Offline
Loc: New York, USA
That is a good idea. I think i will do the same. I have an 07 5.7 with 118k and i just cleaned the throttle body and it was pretty oily/gunky in there. Id hate to see the backside of my valves
25,347 Registered Members
190,237 Topics
Restoration shop in SE Mass area recommendations...
by 440beeper
06/22/18 04:29 PM
C-Body fuel tank set up for efi
by Dart451
06/22/18 04:21 PM
Whiplash 318 question
by Eggman
06/22/18 03:53 PM
$28,000 Dodge 383 D-100 - Virginia
by bigdad
06/22/18 03:32 PM
