Battery Tender Charging "Full" Battery #2366123
09/05/17 11:31 PM
09/05/17 11:31 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Hey guys,
I bought a Battery Tender brand charger (1.25 amp I think) and I decided to use it a bit since I haven't been driving my Charger as much lately (so much work and home projects). I noticed that after I drive the car and park it, if I hook the charger up, it will charge for 12-18 hours before it reads full.
This is after a 25 minute drive or so with the ammeter indicating the battery is topped off (centered). Alt voltage is ~14.5V running.
Granted this is a trickle charger but is this "normal"? Can the charger top off the battery more than the normal charging cycle of the alternator?
Battery is a 2 year old Interstate - not a cheap one either. Otherwise battery and charging system seem healthy. Fires right up and she spins like a top.
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366126
09/05/17 11:36 PM
09/05/17 11:36 PM
Kirkland, Washington
Pacnorthcuda Offline
That's very normal. It's got to go through its program before you get the steady green light.
Re: Battery Tender Charging "Full" Battery [Re: Pacnorthcuda] #2366134
09/05/17 11:44 PM
09/05/17 11:44 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Thank you, sir. I have zero experience with these. My last charger was one my grandfather gave me and built in the 60's (still works) and was a bit less complicated not to mention it can dump 30 amps or so into the battery.
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366137
09/05/17 11:48 PM
09/05/17 11:48 PM
WA
tman Offline
tman  Offline
WA
Yes it is normal. Driving around for that short time is just a surface charge. I leave my Battery Tender on ALL the time when I don't drive it.
Re: Battery Tender Charging "Full" Battery [Re: tman] #2366371
09/06/17 01:21 PM
09/06/17 01:21 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Same Here !!
Re: Battery Tender Charging "Full" Battery [Re: TOMRR] #2366387
09/06/17 01:52 PM
09/06/17 01:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Not me. I have heard too many stories of garages burning down from these trickle chargers. Heck, I even disconnect my cables from my batteries if I am not driving the car everyday such as my nice weather crusing cars. Not on the daily drivers.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366395
09/06/17 01:59 PM
09/06/17 01:59 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
with stock output rates alt on car, that can be pretty much normal it happens. Stock alts barelly can hold the batt fully charged
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366405
09/06/17 02:12 PM
09/06/17 02:12 PM
central il.
second 70 Offline
second 70  Offline
central il.
I use a battery tender junior and switch it between cars every so often. Maybe once a month to fully charge and then I remove it. It works just as you described after driving.
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366596
09/06/17 08:14 PM
09/06/17 08:14 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I've had them go bad where I have the green light but only 10 volts..Also the other way around where it's "charging" constantly when there's no need...I ended up trying another brand the battery tender is just too expensive to be replacing every 5 years or so...
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366795
09/07/17 03:27 AM
09/07/17 03:27 AM
WA
tman Offline
tman  Offline
WA
For $50, it is good insurance and quality product. If it fails in 5 yrs, that's only $10/yr. I use the Battery Tender on my Cuda. Ctek is another good one. I use that one for my generator battery.
My first Batt Tender lasted 7 yrs. On my 2nd one now, going on 4yrs. Much better then buying a battery every 2 yrs like I did before w/o the BT. My Turbostart agm red cap battery still working great since 2010 using the BT. I don't know if Turbostart is still making them. I have no experience with the other makes of red cap batteries.
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366798
09/07/17 03:42 AM
09/07/17 03:42 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I have a Jr. on my bike. I gave $21 for it at Batteries +. I used to get 2 seasons out of a battery, the one in the bike now is 5 years old. Yes, it goes through it's cycle every time I plug the bike back in.
Re: Battery Tender Charging "Full" Battery [Re: cjskotni] #2366923
09/07/17 01:14 PM
09/07/17 01:14 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
The one I purchased from Tractor store ( led lights) is rotated between my 3 cars and motorcycle.. $25 four years ago??
Handiest device I have ever purchased..
