Re: 32 inch tire vs. 28inch tire in 1/8 mile
[Re: moparsquid]
#236581
02/26/09 02:07 AM
02/26/09 02:07 AM
Posts: 2,864 IN
Irun5snd8th
IN
Need to know what kind of power you are laying down. I have a 32 inch tire and 5.13 gear and go through at 6600 in the 1/8th with around 600 HP.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: moparsquid]
#236588
02/26/09 09:01 AM
02/26/09 09:01 AM
Posts: 18 aiken,sc
nrc
aiken,sc
i have a 71 duster it currently has a 383 auto 8-3/4 with 5.13 , 32x14 slicks, should i got to a smaller tire for the 1/8 mile or keep the same size that i have .i want to go thru the lights at around 62-6500 rpm, or would the smaller tire rev to fast for the 1/8th mile track.
seeing as gears are usually figured at 28 inches right now your 5.13 is actually a 4.46 gear,and with the 28 would be a 5.13, but if you wanted to see your rpm difference ,add approximately 13% to what you do in the 1/8 now.but can your car leave with the smaller tire[due to higher gear ratio] bob
