32 inch tire vs. 28inch tire in 1/8 mile #236578
02/26/09 01:36 AM
02/26/09 01:36 AM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
i have a 71 duster it currently has a 383 auto 8-3/4 with 5.13 , 32x14 slicks, should i got to a smaller tire for the 1/8 mile or keep the same size that i have .i want to go thru the lights at around 62-6500 rpm, or would the smaller tire rev to fast for the 1/8th mile track.
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: moparsquid] #236579
02/26/09 01:46 AM
02/26/09 01:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What rpm do you hit the stripe at now?
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: MR_P_BODY] #236580
02/26/09 01:54 AM
02/26/09 01:54 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
sory cant answer that as i just got the car and it needs new skins , need to know the best tire for the 1/8 mile so i can purchase the right ones thanks.
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: moparsquid] #236581
02/26/09 02:07 AM
02/26/09 02:07 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Need to know what kind of power you are laying down. I have a 32 inch tire and 5.13 gear and go through at 6600 in the 1/8th with around 600 HP.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: moparsquid] #236582
02/26/09 02:09 AM
02/26/09 02:09 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Your new car has a ton of gear as it is. Id stick with the 32" tire.
But come on , you could be a whole lot more forthcoming with the details of the car. Dont tell me you bought a car that you know nothing about Except for its gear, tire and 383 engine. Give us some previous performance numbers. mike
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: Sport440] #236583
02/26/09 02:21 AM
02/26/09 02:21 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
sorry to be so vague on the info but the seller bought it from a guy with as little imfo asi got ,car sat for some time last ran at calsbad in the 80s or early 90s,got a screamin deal that i coudnt pass on. possibly ran high tens or low elevens in the 1/4 not shure, just want to get back on the track and have fun,been awile last car was a 63 fury. thanks
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: moparsquid] #236584
02/26/09 02:25 AM
02/26/09 02:25 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
My guess is a tire change from 1/4 mile to 1/8 mile would be of little benefit. I doubt it would make more than .10 difference and more likely about .05
The only time I could see it helping is if you had way too much tire now for the HP you have. Which means a taller gear would be the better answer for both 1/4 and 1/8 mile.
Scott
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: ProStDodge] #236585
02/26/09 02:28 AM
02/26/09 02:28 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks for the help I was thinking that I should keep that size also,again thanks
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: moparsquid] #236586
02/26/09 02:34 AM
02/26/09 02:34 AM
The 383(if it is a stock stroke 383 and not a 3.90 or 3.75 stroker motor) like to RPM a little higher than its bif brother 426 and 440 motor with the same heads, so I would probally get a set of 13x31x15 or a set of 12.25x31.25x15W. I have ran those same size tires on a Duster with a cross ram Hemi bracket motor and a different 440 cross ram bracket motor, those tires would hook either motor on marginal tracks The 14x32x15 are a lot cheaper used ( and use to be a very popular size for SS and tube chassis cars) so maybe that is why there on there still
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: Cab_Burge] #236587
02/26/09 08:53 AM
02/26/09 08:53 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks ill look into those sizes also. BOB
Re: 32 inch tire vs. 28inch tire in 1/8 mile [Re: moparsquid] #236588
02/26/09 09:01 AM
02/26/09 09:01 AM
aiken,sc
nrc Offline
nrc  Offline
aiken,sc
seeing as gears are usually figured at 28 inches right now your 5.13 is actually a 4.46 gear,and with the 28 would be a 5.13, but if you wanted to see your rpm difference ,add approximately 13% to what you do in the 1/8 now.but can your car leave with the smaller tire[due to higher gear ratio] bob
