Shortblock question #236563
02/26/09 12:53 AM
02/26/09 12:53 AM
colorado
a12superbee Offline OP
colorado
Hey guys, I've got a line on a 440 shortblock, the guy who owns it says it's a 77-78 casting with flattops in it. Brand new still in the crate.
My question is, is this one of the mopar performance short blocks (he didn't know) and is it worth getting to build off of or am I better off using what I have now which is a 71 hp motor.
He wants 1300$ if that pushes things one direction or the other.
I need to watch the $'s here. Darn it.
Thanks for any advice.
I can't afford this. mark
Re: Shortblock question [Re: a12superbee] #236564
02/26/09 01:43 AM
02/26/09 01:43 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
A 77 shortblock build will have the pistons down in the hole quite a ways. I would always choose to start with a block, and build the motor I want, choosing each component for a specific reason. Rather than buy a short-block built by somebody who had no idea what I want to do with the motor.
Re: Shortblock question [Re: a12superbee] #236565
02/26/09 01:50 AM
02/26/09 01:50 AM
I would build your 71 so you could order pistons that would give you quench which I'm sure that shortblock would not have and a factory assembly line type shortblock is not going to be built with the care and precision that you would undoubtedly be putting into your 71 since you'd be monitoring every step in the rebuild. Also factory balancing is not noted for being precise. Do it your self & you'll KNOW you have a good foundation and any future upgrades or additions such as cam/carb/intake/heads will not be(potentially) compromised by an inadequate shortblock
Re: Shortblock question [Re: RapidRobert] #236566
02/28/09 07:37 PM
02/28/09 07:37 PM
colorado
colorado
Thanks for the responses guy, about what I thought. Not to be a pest but a bump for the weekend crowd.
For some reason I got it in my mind that the first mopar performance shortblocks were based on the 77-78 blocks, or is that just the fog of age talking?
Re: Shortblock question [Re: a12superbee] #236567
02/28/09 10:50 PM
02/28/09 10:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Stick with what you got. $1300 can buy a lot of horse power with the block you already have.
Re: Shortblock question [Re: stumpy] #236568
03/01/09 04:15 AM
03/01/09 04:15 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I think it would be a stock replacement crate mill...
