'92 D-150 Intermittent Engine Dying
#2365357
09/04/17 07:20 PM
09/04/17 07:20 PM
Posts: 1,286 IN
GTX4spd
IN
5.2 in a '92 D-150, I've narrowed it down to being an ignition problem, not fuel. Wondering whether anyone can give some helpful hints? I replaced the coil before this problem began because of occasional hard-starting issues, haven't put the old coil back yet. There's no obvious problem in sight so ?????
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin
www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: '92 D-150 Intermittent Engine Dying
[Re: GTX4spd]
#2365452
09/04/17 09:50 PM
09/04/17 09:50 PM
Posts: 1,286 IN
GTX4spd
IN
Ummm, no, to be honest, I didn't remember when the OBD system began! I'll try that in the morning. Gettin' old, gettin' tired..............
[Re: GTX4spd]
#2365460
09/04/17 10:04 PM
09/04/17 10:04 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
OBDI was in effect for the 92 Ram, just cycle This should also work for your truck https://www.allpar.com/fix/codes/index.html
[Re: GTX4spd]
#2365463
09/04/17 10:08 PM
09/04/17 10:08 PM
Posts: 1,630 North Central Florida
eightlitermopar
Thanks My 92 d150 had similar issues. It was giving random codes. It turned out the computer was failing. Replaced that and it ran great. However, before I found it was the computer, I replaced the coil, wires, cap, rotor, injectors.....
Mopar or no car
[Re: eightlitermopar]
#2365522
09/04/17 11:43 PM
09/04/17 11:43 PM
Posts: 1,286 IN
GTX4spd
IN
Question A: How do you determine it's the computer? Question B: Where do you get a replacement computer? May be a stupid question, but that's not an issue that I've ever ran into before so it's new territory.
[Re: GTX4spd]
#2365530
09/04/17 11:54 PM
09/04/17 11:54 PM
Posts: 673 Emmett, Idaho
SuperStockWagon
Emmett, Idaho
Same problem with my 90..Ended up being the computer. Bought a used one at the pic and pull. Just make sure you get the same part # thats in your truck now.
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
[Re: SuperStockWagon]
#2365544
09/05/17 12:14 AM
09/05/17 12:14 AM
Posts: 1,286 IN
GTX4spd
IN
It's just a plug-in situation, doesn't have to be 'flashed' by a dealer?
[Re: GTX4spd]
#2365613
09/05/17 02:31 AM
09/05/17 02:31 AM
eightlitermopar
I got mine through NAPA. A mechanic friend of mine help so I don't know the details for a 92 on what information you need to give, if any.
Mopar or no car
[Re: GTX4spd]
#2365650
09/05/17 08:59 AM
09/05/17 08:59 AM
Supercuda
About to go away
About to go away
up yours
Question B: Where do you get a replacement computer? May be a stupid question, but that's not an issue that I've ever ran into before so it's new territory. http://www.rockauto.com/en/catalog/dodge,1992,d150+pickup,5.2l+v8,1084878,electrical,engine+control+module+(ecm+computer),2896
[Re: Supercuda]
#2365660
09/05/17 10:08 AM
09/05/17 10:08 AM
Posts: 1,286 IN
GTX4spd
IN
Thanks everyone for your help. I looked at RockAuto earlier this morning & their rebuild service looks reasonable, haven't pulled this computer out yet to check the serial number. I have a connection at NAPA so I'm gonna look there as well, see if the cost compares. Thanks again.
[Re: GTX4spd]
#2365666
09/05/17 10:20 AM
09/05/17 10:20 AM
Supercuda
About to go away
About to go away
up yours
Don't assume the computer is the problem.
Determine what the problem is first. Runt eh codes, see what, if anything they are.
[Re: Supercuda]
#2365725
09/05/17 12:16 PM
09/05/17 12:16 PM
Posts: 1,286 IN
GTX4spd
IN
Yeah, good advice, especially since all of the listings I find are for Automatics with Cali emissions or high altitude, neither of which apply to this truck.
