5209 hooker headers #2365422
09/04/17 09:02 PM
09/04/17 09:02 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
400 block sr heads milodon dual line pan. stock front end in a 69 satellite. any fitment problems. thks Danny
Re: 5209 hooker headers [Re: plycuda] #2365497
09/04/17 10:53 PM
09/04/17 10:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I would think the 1 pipe on each side would be a little too close but you can re do them if you like to fit not going around the torsion bar.
Re: 5209 hooker headers [Re: Clanton] #2365532
09/04/17 11:56 PM
09/04/17 11:56 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
should fit just fine dan had them on my 63 belvedere with a 69 b body k frame which moves the motor back 2 inches on an early b body used the milodon dual line swinging pick-up and a oil pan for a 69 bird so should fit a 69 even better joe
Re: 5209 hooker headers [Re: plycuda] #2365533
09/04/17 11:57 PM
09/04/17 11:57 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
forgot to mention also on a low deck with sr s
Re: 5209 hooker headers [Re: plycuda] #2365694
09/05/17 11:13 AM
09/05/17 11:13 AM
an8sec70cuda Offline
Low deck w/ SR heads should fit the headers just like a stock headed RB block.
CHIP
'06 GMC 2500HD LBZ Duramax
