'92 D-150 Intermittent Engine Dying #2365357
09/04/17 07:20 PM
09/04/17 07:20 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
5.2 in a '92 D-150, I've narrowed it down to being an ignition problem, not fuel. Wondering whether anyone can give some helpful hints? I replaced the coil before this problem began because of occasional hard-starting issues, haven't put the old coil back yet. There's no obvious problem in sight so ?????
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365423
09/04/17 09:02 PM
09/04/17 09:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you run the codes?
Don't be the exception.
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365452
09/04/17 09:50 PM
09/04/17 09:50 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Ummm, no, to be honest, I didn't remember when the OBD system began! I'll try that in the morning. Gettin' old, gettin' tired..............
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365460
09/04/17 10:04 PM
09/04/17 10:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
OBDI was in effect for the 92 Ram, just cycle
This should also work for your truck
https://www.allpar.com/fix/codes/index.html
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365463
09/04/17 10:08 PM
09/04/17 10:08 PM
North Central Florida
E
eightlitermopar Offline
E
My 92 d150 had similar issues. It was giving random codes. It turned out the computer was failing. Replaced that and it ran great.
However, before I found it was the computer, I replaced the coil, wires, cap, rotor, injectors..... blah
Mopar or no car
Re: '92 D-150 Intermittent Engine Dying [Re: eightlitermopar] #2365522
09/04/17 11:43 PM
09/04/17 11:43 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Question A: How do you determine it's the computer?
Question B: Where do you get a replacement computer? May be a stupid question, but that's not an issue that I've ever ran into before so it's new territory. blush
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365530
09/04/17 11:54 PM
09/04/17 11:54 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
Same problem with my 90..Ended up being the computer. Bought a used one at the pic and pull. Just make sure you get the same part # thats in your truck now.
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: '92 D-150 Intermittent Engine Dying [Re: SuperStockWagon] #2365544
09/05/17 12:14 AM
09/05/17 12:14 AM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
It's just a plug-in situation, doesn't have to be 'flashed' by a dealer?
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365613
09/05/17 02:31 AM
09/05/17 02:31 AM
E
E
I got mine through NAPA. A mechanic friend of mine help so I don't know the details for a 92 on what information you need to give, if any.
Mopar or no car
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365650
09/05/17 08:59 AM
09/05/17 08:59 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.rockauto.com/en/catalog/dodge,1992,d150+pickup,5.2l+v8,1084878,electrical,engine+control+module+(ecm+computer),2896
Re: '92 D-150 Intermittent Engine Dying [Re: Supercuda] #2365660
09/05/17 10:08 AM
09/05/17 10:08 AM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Thanks everyone for your help. I looked at RockAuto earlier this morning & their rebuild service looks reasonable, haven't pulled this computer out yet to check the serial number.
I have a connection at NAPA whistling so I'm gonna look there as well, see if the cost compares.
Thanks again.
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365666
09/05/17 10:20 AM
09/05/17 10:20 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't assume the computer is the problem.
Determine what the problem is first. Runt eh codes, see what, if anything they are.
Re: '92 D-150 Intermittent Engine Dying [Re: Supercuda] #2365725
09/05/17 12:16 PM
09/05/17 12:16 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Yeah, good advice, especially since all of the listings I find are for Automatics with Cali emissions or high altitude, neither of which apply to this truck.
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365730
09/05/17 12:25 PM
09/05/17 12:25 PM
moparx Offline
moparx  Offline
another thing to look at. before replacing the computer, look VERY closely at the plug. i have seen, and repaired, wires at the plug because the underhood heat had cracked the insulation, allowing corrosion to wick into the wire[s], causing many mysterious conditions.
beer
Re: '92 D-150 Intermittent Engine Dying [Re: GTX4spd] #2365912
09/05/17 05:26 PM
09/05/17 05:26 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Distributor pick up
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
