EFI Distributor #2364792
09/03/17 07:27 PM
09/03/17 07:27 PM
IN
ahy Offline OP
ahy  Offline OP
IN
I am afraid it is time to change the Accel "dual sync" distributor that has served me well for ~15 years.
The crank signal became intermittent and the car was bucking. Switch to batch fire which does not use the crank signal cleared it up for a while and now the cam sensor is acting up.
I really like having sequential EFI and my engine was tuned for it... but right now a simple distributor would get her going on batch fire... and maybe crank trigger down the road.
Suggestions for replacement distributor welcome.
Re: EFI Distributor [Re: ahy] #2365186
09/04/17 02:21 PM
09/04/17 02:21 PM
AndyF Offline
AndyF  Offline
What engine? I have a couple of ready to run distributors for sale in the parts section for RB engines. I also have a Holley Dual Sync for an RB that I'd sell.
Re: EFI Distributor [Re: AndyF] #2365261
09/04/17 03:55 PM
09/04/17 03:55 PM
IN
ahy Offline OP
ahy  Offline OP
IN
Andy,
Its a B engine. The Accel dual sync is acting up and does not appear to be very serviceable.
Short term, a simple trigger distributor for the XFI computer + MSD 6 box will get her going. I will probably add a crank trigger later to get the sequential capability back.
Whatever I get will be locked out and the XFI controls timing. I run a blaster coil.
So far my list includes 1) simple reman distributor from the parts store. Readily available and low cost. Cons are I need male connectors on the cap and I'm not sure how a reman would like 6,000-6,500 RPM and somewhat higher secondary loads. Also not sure how to lock it out (welding?) 2) Basic Firecore performance distributor. I think this will handle the application, male plug connectors and extra clearance around the cap is nice. Not sure how to lock this one out either but I am guessing there is provision. 3) MSD billet distributor. Bigger cap but should fit as well as the Dual Sync I have now.
Re: EFI Distributor [Re: ahy] #2365535
09/05/17 12:02 AM
09/05/17 12:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Andy, how does that Holley Dual Sync fit? What I mean is I have the FAST dual sync and had the grind the lower part of my Stealth heads for it to fit. The upper cap part just clear the head with maybe 1/16" clearance.
Re: EFI Distributor [Re: 451Mopar] #2365637
09/05/17 06:31 AM
09/05/17 06:31 AM
IN
ahy Offline OP
ahy  Offline OP
IN
The Holly/Accel dual sync has a taller base vs the FAST offering and fits OK at the bottom. My cast MP valve covers had to be relieved to fit the cap.
Re: EFI Distributor [Re: ahy] #2366051
09/05/17 09:34 PM
09/05/17 09:34 PM
IN
ahy Offline OP
ahy  Offline OP
IN
Update... I ordered the Firecore "race" distributor. Looking forward to good fit and mostly getting her running well again.
I have some ideas and hopefully a future post on how to install crank trigger (to get sequential EFI capability back) with no impact on pulley and belt spacing.
Re: EFI Distributor [Re: ahy] #2367100
09/07/17 06:10 PM
09/07/17 06:10 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Check out the offerings that Andy F has for a crank trigger, some really nice stuff. I have his trigger wheel on my small block.
Here is a link to some of his stuff through Fastman EFI
http://www.fastmanefi.com/cnp-products-for-mopars
68 Barracuda Formula S 340
