Re: valve tips one or two grooves
[Re: moparpro]
#2364454
09/03/17 11:29 AM
09/03/17 11:29 AM
RapidRobert
As you know the # of lock grooves would need to match the # of grooves in the stem & the lock degrees would need to match the retainer degrees. You have the valves & need compatible locks/retainers?
[Re: moparpro]
#2364486
09/03/17 12:19 PM
09/03/17 12:19 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Also the stem size.They do make different sizes.Rocky
Chrysler Firepower
[Re: moparpro]
#2364621
09/03/17 03:06 PM
09/03/17 03:06 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I guess the first question should be....... Do you need 10deg retainers and locks?
In addition to needing the correct locks to fit your valves, 10deg locks require the use of 10deg retainers, and the retainers have to fit whatever springs you plan on running.
Comp Cams has 36 different part numbers for 10deg retainers.........It's not one size fits all.
[Re: Porter67]
#2364898
09/03/17 11:53 PM
09/03/17 11:53 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
CAB or ? define stable lobe, please? A unstable lobe can and some will cause valve float from 4800 RPM and above, Some lobe designs do it later than other do If your motor is eating up the top of the valve stems needing constant valve adjustments or wearing out the valve springs, keepers and retainer you more than likely have unstable camshaft IHTHs Most motor problems will talk to you , under standing what they are saying sometimes is the hard part
