Transmission Dipstick 727 #2364192
09/02/17 06:57 PM
09/02/17 06:57 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
What brand are you guys using ??
I was in a pinch ( need to get the car running ),,,and picked up a locking dipstick at the local speed shop...
brand is ALLSTAR ??
No luck,,,fit is terrible,,,does not line up at all with the bellhousing OMG.....whoever welded the mounting tab on this stick needs some new glasses.....
I usually use CRT,,,but needed something in a hurry,,,
What other brands do you guys like ??
Will call John @ CRT after the holiday's,,,arrrgghhhh
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364196
09/02/17 07:02 PM
09/02/17 07:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Locar flexible
wave
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364197
09/02/17 07:03 PM
09/02/17 07:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
BB and SB mounting tabs are different...are you sure the tube is for your block?
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364204
09/02/17 07:25 PM
09/02/17 07:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The BB part number is : 69121
If that's what you have and it doesn't fit right..... Perhaps it's a SB part that's packaged wrong.
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364206
09/02/17 07:34 PM
09/02/17 07:34 PM
tboomer Offline
tboomer  Offline
Hi Doug! How ya been? On my 64 I went to the boneyard a got a locking dipstick off a 98 GMC 2500. Cut it for length and it fit my 727 tube just fine! Ted wave
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364235
09/02/17 09:23 PM
09/02/17 09:23 PM
KENTUCKY
KENTUCKY
Yup. Big block. At least that is what the package said.
Hi Ted !! Thx for the idea. Hope your well.
Hi Mike. Saw the lokar. Looks nice.
Was hoping to get some fluids in the car to fire it up over the holiday weekend.
Thanks everyone! 👍
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364321
09/03/17 12:19 AM
09/03/17 12:19 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I've used both the Lokar and one from Mancini. Like the mancini one best. Sat a little higher and was able to get it out w/o burning my knuckles.
Ok
Re: Transmission Dipstick 727 [Re: tboomer] #2364336
09/03/17 12:40 AM
09/03/17 12:40 AM
Mopar has offered a bunch of different dip sticks and tubes for both BB and Hemi in different body models and years shruggy
The early B body M.W. tubes came up behind the passenger head, the non M.W. BB came up along the rear of the block below the exhaust manifolds shruggy
I have kept all of the old ones I can get up devil
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364345
09/03/17 12:52 AM
09/03/17 12:52 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I just tried a TCI locking dipstick....fit perfectly.
A new iron curtain drawn across the 49th parallel
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364359
09/03/17 01:32 AM
09/03/17 01:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Junkyard locking dip stick off of a Astro van iirc.........many years ago and cut it and mark to fit based on the original....... thumbs
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364507
09/03/17 12:45 PM
09/03/17 12:45 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The cope trans stick is a good one.
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364641
09/03/17 03:28 PM
09/03/17 03:28 PM
KENTUCKY
KENTUCKY
Thanks everyone,,,,
I have used CRT ( Cope ) before on the race car,,,no issues,,,
Will give John a call on Tuesday,,,,
I found a "stock" one to use for now,,,,but not crazy about the fit at the trans,,,has a small rubber "O" ring,,,hopefully no leaks,,,,
wink
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2364967
09/04/17 01:31 AM
09/04/17 01:31 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
A stock tube will work just fine, provided: No one has muscled and wiggled it back and forth, to get it out. Litteraly millions with that oring.
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2365006
09/04/17 04:13 AM
09/04/17 04:13 AM
All I have ever used in 727 is stock tubes and matching dip dipsticks up shruggy
Make sure the tube is NOT bent at the O ring indentation before using it and use the proper scope twocents O ring
Re: Transmission Dipstick 727 [Re: 69CHARGERMD] #2365689
09/05/17 11:05 AM
09/05/17 11:05 AM
an8sec70cuda Offline
Lokar flexible braided steel trans dipstick here.
CHIP
'06 GMC 2500HD LBZ Duramax
