Re: coverting direct drive starter to gear reduction...?
[Re: groovy ghoulie]
#236407
02/25/09 10:24 PM
02/25/09 10:24 PM
RapidRobert
easiest would be to run a wire from your ign switch "start" down to the solenoid terminal on the new starter or if the ign sw has no place for that then a seperate pushbutton sw or better yet since the brown wire looks like it handles a fair amt of current would be to convert to a modern 4 terminal starter relay
[Re: RapidRobert]
#236409
02/25/09 10:47 PM
02/25/09 10:47 PM
You don't need any "separate buttons" there should be as posted above a "Ford" style solenoid,
if the existing solinoid is good, run the existing battery wire to the new starter just like the old, and make a short jumper between the large and small terminals on the new starter
I believe the old solenoid will have two small terminals, and I BELLIEVE that the second terminal is wired to the neutral safety switch
If you need a new solenoid, there are some years of Jeep that use this wiring scheme, that is, two small terminals on the starter solenoid that connect to the coil. These are NOT THE SAME as the popular Ford solenoid used for so many years
