Molded gasket windage tray: Anybody use one? #2363849
09/02/17 01:05 AM
09/02/17 01:05 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I was looking at the big block molded gasket windage trays that Summit sells and was wondering if anyone here has used one and if so, how is it? Also, do you have to use any sealer on it?
Re: Molded gasket windage tray: Anybody use one? [Re: 440mopar] #2363852
09/02/17 01:09 AM
09/02/17 01:09 AM
I redid a 440 six pack motor this summer for a local car show guy, it had one of those plastic molded ones in it with the stock crank, I reused it with the new 4.25 stroke crankshaft with no issues up
I have since bought some to use on future projects up
BTW, I do make and use my own crankshaft scrapers also up
Re: Molded gasket windage tray: Anybody use one? [Re: Cab_Burge] #2363860
09/02/17 01:21 AM
09/02/17 01:21 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Did you have to use any sealer on it?
Re: Molded gasket windage tray: Anybody use one? [Re: 440mopar] #2363864
09/02/17 01:27 AM
09/02/17 01:27 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
They work best on a cast pan with a flat mating surface.
Used one on a stock-type pan and did not have good luck because
of all the stiffening ridges on the pan did not match up well with the tray's seal.
This was a couple of years ago when they first came out, so maybe they
changed the design.
Joe
Re: Molded gasket windage tray: Anybody use one? [Re: jlatessa] #2363872
09/02/17 01:42 AM
09/02/17 01:42 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I used one on the 440 that we just rebuilt for my Dart. No leaks so far...I also used a new oil pan too.
Re: Molded gasket windage tray: Anybody use one? [Re: jlatessa] #2363998
09/02/17 12:12 PM
09/02/17 12:12 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
changed the design.
Joe
https://www.summitracing.com/parts/sum-g2340/overview/make/chrysler
If you enlarge the picture in that link
I agree , especially with the area around the dipstick , not even close on the factory 402 Oil Pan
And other areas where only one of the two silicone rubber o ring material would seal along side the stiffening indentations of the factory oil pan
Didn't work for my 402 Oil Pan
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Molded gasket windage tray: Anybody use one? [Re: 440mopar] #2364016
09/02/17 12:55 PM
09/02/17 12:55 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I have one
It is in a 451 using a milodon pan.
It seems ok, except for the one mystery leak from one of the forward middle bolts in the timing cover.
Just a slow leak from the one bolt no matter how tight.
I like it and would use it again.
1974 Roadrunner
1967 Charger
