904 Trans
#2363528
09/01/17 03:26 PM
09/01/17 03:26 PM
Posts: 4,454 Morristown Tn.
71birdJ68
Morristown Tn.
75 Dart with /6 and 904,is not wanting to start in park, which plastic part is usually the one causing this, and can they be found anywhere? Thanks.
Re: 904 Trans
[Re: 71birdJ68]
#2363582
09/01/17 04:26 PM
09/01/17 04:26 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The plastic bushings support the linkage shafts, if they're worn or fall out the gear positions will be incorrect. Originals are usually white.
Re: 904 Trans
[Re: 71birdJ68]
#2363623
09/01/17 05:29 PM
09/01/17 05:29 PM
RapidRobert
I would undo the linkage at its' easiest junction to come apart (as you know some of those press in bushing are TIGHT) & move the flat horizontle lever to park & neutral & see if the middle pin has continuity to the trans case & if all good there then see about a slight adjustment to the linkage or the bushing as needed.
