master cyl part #'s #236267
02/25/09 07:52 PM
02/25/09 07:52 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Converting to manual brakes. Need part number to late model master cylinder 2 bolt style. I'm using a mancini style adapter. Thx
Re: master cyl part #'s [Re: clyde] #236268
02/25/09 08:44 PM
02/25/09 08:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Disc all around or disc drum
Re: master cyl part #'s [Re: MR_P_BODY] #236269
02/25/09 09:10 PM
02/25/09 09:10 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
disc and drum
Re: master cyl part #'s [Re: clyde] #236270
02/25/09 09:22 PM
02/25/09 09:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The Mopar ones are P5249270 which is a 15/16 bore
and P5249271 which is a 1 1/32 bore, or you can a
Dakoda master that has a 1 1/8 bore ... I dont have that
number
Re: master cyl part #'s [Re: MR_P_BODY] #236271
02/25/09 09:23 PM
02/25/09 09:23 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Thank You Sir.
