Page 2 of 4 1 2 3 4
Re: Trick Flow 240 users [Re: OUTLAWD] #2354982
08/16/17 05:50 PM
08/16/17 05:50 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Originally Posted By OUTLAWD
Originally Posted By Dbl"00"Joe
Here's mine,
1970 Cuda weighs 3490
446 ci RB 10.5 compression Pump Gas
Stock 440 steel crank Icon pistons and Scat Rods
Victor Intake and old style 950hp (small venturi)
260ish solid flat tappet cam ootb 240"s with Smith bros push rods and Harland Sharp 1.5 Rockers
2" Hooker super comp headers and 3" exhaust with Magnaflow Mufflers
8" ATI converter
Its ran a best of 10.42 @ 127 @ US 131
Lift? or its top secret?
.619 thumbs
Re: Trick Flow 240 users [Re: dartman366] #2355535
08/17/17 04:30 PM
08/17/17 04:30 PM
IL
Dart451 Offline
Dart451  Offline
IL
What timing is everyone running, right now I'm at 34 deg
Re: Trick Flow 240 users [Re: dartman366] #2355751
08/17/17 10:49 PM
08/17/17 10:49 PM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
Sorry to go off topic but is trick flow thinking about sound a small block head as well?
Re: Trick Flow 240 users [Re: Dart451] #2355753
08/17/17 10:51 PM
08/17/17 10:51 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
I am at 34 deg myself.
Re: Trick Flow 240 users [Re: dartman366] #2355766
08/17/17 11:01 PM
08/17/17 11:01 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
I'm at 36 deg. Never tried anything else though.
Re: Trick Flow 240 users [Re: DblOJoe] #2355779
08/17/17 11:08 PM
08/17/17 11:08 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I started out conservative with 32* then bumped up to 34*, seemed to help a little but it was hotter and more humid when I bumped up than it was at lower temp and humidity, I am going to try 36 after I do some other tunin'.
Re: Trick Flow 240 users [Re: relax383] #2356277
08/18/17 10:35 PM
08/18/17 10:35 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I personally have not heard any talk of it.
Re: Trick Flow 240 users [Re: dartman366] #2356310
08/18/17 11:59 PM
08/18/17 11:59 PM
AndyF Online content
AndyF  Online Content
Second hand information that I have says TF tried to do a small block Mopar head and gave up on it. I don't know any specific information but I did talk to a guy who said he knew about the head and that it the project got cancelled for some reason. Not sure if it was a technical reason or a marketing decision.
Re: Trick Flow 240 users [Re: AndyF] #2357848
08/21/17 10:38 PM
08/21/17 10:38 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
bumpI know there has to be more than 5 guys that are running these heads. shruggy
Re: Trick Flow 240 users [Re: dartman366] #2357861
08/21/17 11:05 PM
08/21/17 11:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
When I talked to the Trick Flow guys at Norwalk 4-5 years ago I told them that the big block Mopar market was pretty flooded and there was more need for a GOOD small block head. He asked if his Friends could join the conversation and 5 of us sat there for 30 minutes BSing. Several of the employees thought the same thing but it was to far along to do anything about it. They will sell some heads but there are only so many big block Mopar guys.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trick Flow 240 users [Re: dartman366] #2357951
08/22/17 01:32 AM
08/22/17 01:32 AM
eastern,Ky
70RT Charger Offline
eastern,Ky
68 448 RB Squared and Zero decked with CR @ 10.7:1
Custom Lightweight Race Tec Pistons, factory turned steel crank, factory LY rods with ARP rod bolts, Comp XR 286 HR Cam, Trick Flow Roller Lifters, TF 240 Heads, Mancini 1.6 Roller Rockers, Smith Bros Push Rods, Holley Street Dominator, TTI 1 7/8 Ceramic Coated Headers, 6 quart Hemi pan, 391 gears. Have not made my mind up on a Carb yet. T-56 Magnum 6-speed from SST with Hydraulic Clutch.
Re: Trick Flow 240 users [Re: dartman366] #2357968
08/22/17 02:22 AM
08/22/17 02:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I started the project, and funds dried up.
I got all the top end, Lunati Voodoo Solid Roller cam #40230732LK. 273/279 adv. 243/249 @ 0.050" Duration, 0.578"/585" lift @ 1.5:1 ratio,
110 LSA, 106 ICL. 0.61653"/0.624" @ 1.6:1 rocker ratio. 0.016" lash.
Trick Flow TFS-6161T784-C00 Heads. Had the heads checked out and flowed and they were good to bolt on out of the box and flowed almost exactly as advertised. Using the TF recommended HS 1.6:1 rocker arms.
This will be on a 505" stroked 440, with the 27cc dished pistons (around 10:1 compression.)
I figure this should be close to 600 HP?
Using the Holley Street Dominator for hood clearance, so it might cost some power? and also using the FI Tech Go EFI 8 Power Adder Plus 1200 Fuel Injection.
I don't think the 215 wide BFG street tires will last too long smile
Re: Trick Flow 240 users [Re: 451Mopar] #2358018
08/22/17 10:11 AM
08/22/17 10:11 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Even 275 drag radials have problems with this type of combo on the street. Brutal torque!
'63 Dodge 330
11.19 @ 121 mph
Re: Trick Flow 240 users [Re: carter] #2361156
08/28/17 02:17 PM
08/28/17 02:17 PM
sweden
carter Offline
carter  Offline
sweden
Originally Posted By carter
512ci sitting in a bone stock E-body, 3860 with driver. This is my weekend cruiser that see a track once or twice a year. Beting on it for two summers since I built it, old school and simpel.
4.25 x 4.375. B-block
TF 240 OOTB. 802-COO
10.4:1
Holley 850 DP (4781)
Holley SD intake with 1" open spacer
MP .528 with 1.6 rockers
6 Quarter "Hemi pan"
MP Dist 18°/36°
Carter mech fuel pump with 3/8" original fuel line
TTI 1 7/8 headers with full 3" exhaust
T/A 10" converter flash 4400 rpm
Rear 3.91 and 9x28 slicks
Engine has plenty of vacuum for my factory PDB and sound "stock". Best ET so far is 7.29 x 94 MPH.
I hope for one more day at the track so I can do some more adjustments before I change camshaft.
I had the opportunity to take my car to the track this saturday. Last time I was at the track I remember to check out my A/F gauge the last pass and It was lean on WOT.
Now I made tree passes and every time I put in bigger jets and it responded with higher Mph.
New best is 7.19@95.61
Re: Trick Flow 240 users [Re: dartman366] #2361517
08/29/17 01:40 AM
08/29/17 01:40 AM
Idaho
LaRoy Engines Offline
Idaho
They seem to be okay. The owner has never even driven the car yet, but, .030" over 440, 3.75 stock stroke. 9.9:1 compression, six pack, 590 HP and 574 lb-ft all before 6,000 rpm. 574 lb-ft @ 3,500 rpm and 502 lb-ft @ 6,100 rpm. I think it will move the Road Runner if he ever starts and goes someplace with it. Busy making it pretty.
Re: Trick Flow 240 users [Re: dartman366] #2361523
08/29/17 01:58 AM
08/29/17 01:58 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It would be interesting to see a set of 240's used on a high cr stock stroke race type build with a high rpm intake manifold to see where the peaks occur.
Re: Trick Flow 240 users [Re: fast68plymouth] #2361686
08/29/17 01:30 PM
08/29/17 01:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Based on the TF 240 CSA measurements that were posted HERE, I'd say it's going to be RPM-limited comparable to a non-MW Stage VI port.
Where did you see the peaks for the bracket Stage VI combos you built in the past? I know my "less serious" stock-stroke build was 6300-6400 for HP and 5000-5200 for torque.
Re: Trick Flow 240 users [Re: fast68plymouth] #2361689
08/29/17 01:34 PM
08/29/17 01:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
On the dyno my 470 was still pulling and making power at 7000 w/the standard port window RPM's w/around 228 cc intakes and I too am curious about where they would peak w/a fairly stout solid roller........... thumbs
Re: Trick Flow 240 users [Re: dartman366] #2361698
08/29/17 01:47 PM
08/29/17 01:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
I built a 13:1 rb451 with 300cfm rpm heads that made peak tq at 5800, peak hp at 7000...... Be curious to see how similarly built motor using the 240's would turn out.
Re: Trick Flow 240 users [Re: fast68plymouth] #2361777
08/29/17 03:55 PM
08/29/17 03:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya, me too...........
Page 2 of 4 1 2 3 4
