Wilwood pads and rotors
#2361599
08/29/17 10:47 AM
08/29/17 10:47 AM
Posts: 326 Alberta
Wookie316
Alberta
I'm going to buy a lottery ticket. On my last pass this past weekend something did not feel right in the front. Wasn't sure if a wheel bearing was starting to go or what? I was able to check it out last night and low and behold real bad spider cracks in each rotor and one of the pads, the material came off. That was the noise I was hearing/feeeling. They are 11" rotors with 4 piston calipers. They are the drilled and slotted ones. I believe the P/N#'S are 160-7099/160-7100 rotor & 150-8850 BP-10 pads. Anyone experience this? Should I be using a different material pad? Should I use a non drilled rotor? Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Wilwood pads and rotors
[Re: Wookie316]
#2361601
08/29/17 11:00 AM
08/29/17 11:00 AM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
Yikes! Following. Glad you are safe! Mine are not drilled and it's probably about time I changed the pads.
Better get inside Ma. Looks like a storm's comin'.
[Re: Wookie316]
#2361618
08/29/17 11:34 AM
08/29/17 11:34 AM
Posts: 326 Alberta
Wookie316
Alberta
Ok. So I'm fine to replace with what I had then just put pads in sooner? Need to order today so I have in time for next race. Thanks.
[Re: J_BODY]
#2362009
08/29/17 10:40 PM
08/29/17 10:40 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
If that 4100 in your sig is the car weight then there is your answer.
I also learned the hard way that you don't let the pads wear very far. Leads to pistons sticking out too far. I've talked to a few that said 1/2 and chuck em. Put me on that list Jay Wookie you might talk to Wilwood and see if another pad type would be better for you
"Just a Bracket car dressed up like a streetcar"
[Re: Wookie316]
#2362054
08/29/17 11:37 PM
08/29/17 11:37 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I'm going to buy a lottery ticket. On my last pass this past weekend something did not feel right in the front. Wasn't sure if a wheel bearing was starting to go or what? I was able to check it out last night and low and behold real bad spider cracks in each rotor and one of the pads, the material came off. That was the noise I was hearing/feeeling. They are 11" rotors with 4 piston calipers. They are the drilled and slotted ones. I believe the P/N#'S are 160-7099/160-7100 rotor & 150-8850 BP-10 pads. Anyone experience this? Should I be using a different material pad? Should I use a non drilled rotor? Thanks. That is a lot of heat so maybe you are on them too long and a hotter pad would slow you faster.
[Re: Wookie316]
#2362106
08/30/17 12:57 AM
08/30/17 12:57 AM
Posts: 326 Alberta
Wookie316
Alberta
Where is best to set an adjustable proportion valve? Maybe I have too much front and not enough rear? I have disk on the back and hydroboost as well. I will see what Wilwood recommends for pad material.
[Re: Wookie316]
#2362176
08/30/17 08:45 AM
08/30/17 08:45 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Pad material is critical. And I would probably check your brake balance. Look at your rear brakes. If there is minimal wear on pads and rotors, then yes, you might need more pressure towards the rear.
[image][/image]
[Re: Wookie316]
#2362209
08/30/17 10:43 AM
08/30/17 10:43 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Wookie316...we are in the same boat. My car is about 3900 lbs and hard on brakes. Right now I have the same issue w/ my Aerospace front discs and stock 11" rear drums. I thought I had my car ready to race a few weeks ago until I happened to look at the front rotors. I noticed they were discolored and had a LOT of cracks in them.
BTW...the guy at Aerospace told me that vented and/or crossdilled rotors are not a benefit on a drag or street/strip car. Told me to get the solid rotors. The more surface area you have for the pad to contact, the better. The new pad technology doesn't need to vent gases away from the contact area like the old days. He said they might not look as cool, but will work better.
I really need to upgrade to rear discs.
[Re: an8sec70cuda]
#2362233
08/30/17 11:16 AM
08/30/17 11:16 AM
Clanton
northern,Ohio,USA
I really need to upgrade to rear discs. I have frt,rear pro street disc with undrilled vented rotors and they have held up well
[Re: Wookie316]
#2362248
08/30/17 11:50 AM
08/30/17 11:50 AM
Posts: 326 Alberta
Wookie316
Alberta
One thing I can do is use the 2nd return road instead of the first at the one track I run at. Have to stand on the brakes pretty hard to make first one. May as well save the equipment and use the 2nd one.
[Re: Wookie316]
#2362255
08/30/17 12:03 PM
08/30/17 12:03 PM
an8sec70cuda
LOL, I don't have a prayer of taking the first one at Darlington unless I click it off at the 1/8.
[Re: Wookie316]
#2362267
08/30/17 12:25 PM
08/30/17 12:25 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I was talking to Jim bongard, who is the NHRA inspector for our area. He said that the drilled Wilwood vented rotors have had problems breaking up. One of the victims called Wilwood and they said that anything over 140 miles an hour should use a solid rotor not vented.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Wookie316]
#2362314
08/30/17 01:49 PM
08/30/17 01:49 PM
Posts: 326 Alberta
Wookie316
Alberta
That's what I suspected. That drilled rotors are propably inferior for my application.
[Re: Wookie316]
#2362350
08/30/17 02:58 PM
08/30/17 02:58 PM
Clanton
northern,Ohio,USA
That's what I suspected. That drilled rotors are propably inferior for my application. I hope you can change rotors without changing the hub.
[Re: Wookie316]
#2362372
08/30/17 03:47 PM
08/30/17 03:47 PM
Posts: 326 Alberta
Wookie316
Alberta
Yes. Already apart and waiting for replacements. All good.
[Re: Wookie316]
#2362383
08/30/17 03:56 PM
08/30/17 03:56 PM
Clanton
northern,Ohio,USA
Yes. Already apart and waiting for replacements. All good. I will remember that if I ever switch,Thanks.
