Can you identify these?
#2361282
08/28/17 07:07 PM
08/28/17 07:07 PM
Posts: 486 Sonoran desert, Arizona, USA
moparjo68
Is anyone able to tell if these are mopar wheels? They are suppose to be 15x6 with a 4.5 BP. And would they fit a 68 Charger? I don't know the back spacing.
Re: Can you identify these?
[Re: moparjo68]
#2361294
08/28/17 07:22 PM
08/28/17 07:22 PM
Posts: 106 waco tx
gogo318
waco tx
At first glance yes they look like Mopar Wheels Prime indicator is look around valve stem for the penta star symbol there should also be the dimensions sometimes not always on the other side of the valve stem I could not tell you if it fits your particular charger or not
67 charger fastback 318 stock
67 belvedere II 4dr soft top built 318
68 newport 2dr hard top 318
84 b150 440/727
84 d150 short wheel step side 4x4 lifted
87 omnitruck (you just have to see it )
new addition 63 dart wagon !!!
[Re: moparjo68]
#2362068
08/29/17 11:58 PM
08/29/17 11:58 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
at first sight they looked Phord to me, but my first thought was wrong... they seems to be Mopar
[Re: dogdays]
#2362545
08/30/17 09:55 PM
08/30/17 09:55 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Can you get info from the seller? The center register looks like it might be a tad large. Might just be my old eyes. Says ferd to me. The may fit the 5X4.5 MOPAR bolt pattern but you want the center hole to match your spindle or hub as well, to be MOPAR.
I have mechanical Aptitude. I can screw up anything.
