Re: Valve Spring Suggestions
[Re: RATTRAP]
#2361155
08/28/17 02:16 PM
08/28/17 02:16 PM
Posts: 43,254 Bend,OR USA
Cab_Burge
What type of lifters and lift?
[Re: RATTRAP]
#2361207
08/28/17 04:27 PM
08/28/17 04:27 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
How long have you been running the springs that are in there.
What does the cam manufacture recommend for pressures and go from there
What type of lifters and lift.
They have been in for around 8 years. Cam Card says, Spring Press 145 seat 350 open. Solid lifter .632 intake & .640 exhaust.
ON INDY PDF 2” spring height, spring seats 1.550”
[Re: RATTRAP]
#2361211
08/28/17 04:38 PM
08/28/17 04:38 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
You might look into the K-motion K-800 springs for that lift and cam. I ran them on a small block with a .650 solid roller with good luck. I ran them on drag week which had hours of 3000-3800RPM highway time on them. I did change them every year before drag week but I never had a problem, just did it for insurance.
68 Barracuda Formula S 340
[Re: Cab_Burge]
#2361414
08/28/17 10:51 PM
08/28/17 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
All I use now days(last 6 years I think) have been the Pac springs... nicest springs out there for the price... as Cab said pull a couple and check them
