Re: who makes a-body upgraded disc brake setup
[Re: mxbeep]
#236106
02/25/09 07:40 PM
02/25/09 07:40 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
friend of mine is looking at installing 4 wheel disc on his 71 a-body.
He already as stock front discs with larger bolt pattern front and rear.
He is looking for a pro touring setup.
who sells aftermarket 4 wheel disc setups or is there a cheaper alternative using brake parts from a modern car. thanks
For the front
He can bolt on a set of 11.75" dia rotors from the parts store for like ~$75ea or less. And then buy the 11.75" caliper adapters for alike $50-$75 a set. Same bearing and calipers he has now.
Will not look bling but will work as good a 10.75" rotors with 4 piston drag car brakes like in the wilwood basic kit.
[Re: goldduster318]
#236110
02/25/09 08:40 PM
02/25/09 08:40 PM
Posts: 1,624 qc
mxbeep
qc
thanks for info, to order these parts from parts store, which year and model car for application do i ask
you have to get the adapters used. To get the rotors, just tell them you have a 78 Cordoba with a 400
Which car as these adapters so i know what to look for?
thanks
[Re: Rhinodart]
#236113
02/25/09 10:51 PM
02/25/09 10:51 PM
moparpollack
Lil Herman
Lil Herman
85086
Msster Power Brakes http://www.mpbrakes.com/ makes them for A-Bodies. We use SSBC http://www.ssbrakes.com/ on the Pro-Touring cars that we build at Time Machines. http://www.timemachinesinc.com/
The MPBrakes is cheap what brand of ball joints are they using?
