Re: Parts don't match - spindle & lower ball joint
[Re: lostdog]
#2360818
08/27/17 09:41 PM
08/27/17 09:41 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
the top one has about 4 1/4" spacing - but your tape measure end isn't really lining up to anything around the hole so it's hard to tell. measure from one side of a hole, and then the same side of the other hole - like in the second picture.
the bottom one has 3 5/8th" or 3 11/16th"spacing.
Look at the old ball joint, and the mount, and see if there are a part numbers on them.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2360832
08/27/17 09:58 PM
08/27/17 09:58 PM
Posts: 361 mississippi
lostdog
mississippi
Look at the old ball joint, and the mount, and see if there are a part numbers on them. Unfortunately, i do not have the ball joint that was on there. I just remeasured both at hole centers. Spindle center-to-center hole spacing is 4 3/8" Lower ball joint center-to-center hole spacing is actually 3 3/4"
[Re: lostdog]
#2360858
08/27/17 10:51 PM
08/27/17 10:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
sounds like you got a 9" drum LBJ for an A body Cuda.
[Re: Supercuda]
#2360877
08/27/17 11:18 PM
08/27/17 11:18 PM
lostdog
mississippi
sounds like you got a 9" drum LBJ for an A body Cuda. And that was my first thought as to what has happened but I don't know enough to know.
[Re: lostdog]
#2361114
08/28/17 12:55 PM
08/28/17 12:55 PM
Supercuda
About to go away
About to go away
up yours
You definitely have the early A body drum ball joint.
What's the part number of the LBJ?
Take it back and get the proper ones.
[Re: krautrock]
#2361116
08/28/17 12:57 PM
08/28/17 12:57 PM
lostdog
mississippi
is there a part number on the spindle? looks like it might be the post 1973 a-body disc brake spindle. the part numbers are 3402626 and 3402627, on the upright of the spindle. if that's the case you just need moog k781 and k783 lower ball joints. Ok - that's a big help. I'll look for the numbers when I get home. Also, I got all these pieces in a kit including the idler arm. I'm concerned now that I may have the wrong idler. Thank you !
[Re: Supercuda]
#2361118
08/28/17 12:58 PM
08/28/17 12:58 PM
lostdog
mississippi
Take it back and get the proper ones. There are no part numbers on the LBJ
[Re: lostdog]
#2361196
08/28/17 04:01 PM
08/28/17 04:01 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Where did you get the kit from? Seems they mis-packaged or sold you the incorrect parts.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2361221
08/28/17 04:58 PM
08/28/17 04:58 PM
lostdog
mississippi
Where did you get the kit from? Seems they mis-packaged or sold you the incorrect parts. It was an ebay item. I should have known better ! As a matter of fact, I do know better but I did it anyway.
[Re: krautrock]
#2361366
08/28/17 09:21 PM
08/28/17 09:21 PM
lostdog
mississippi
is there a part number on the spindle? looks like it might be the post 1973 a-body disc brake spindle. the part numbers are 3402626 and 3402627, on the upright of the spindle. if that's the case you just need moog k781 and k783 lower ball joints. I've looked everywhere on the spindles and all I can find is a "32" cast into one and a "31" cast into the other. Does that denote something ?
[Re: lostdog]
#2361409
08/28/17 10:44 PM
08/28/17 10:44 PM
Posts: 2,094 central texas
krautrock
central texas
is there a part number on the spindle? looks like it might be the post 1973 a-body disc brake spindle. the part numbers are 3402626 and 3402627, on the upright of the spindle. if that's the case you just need moog k781 and k783 lower ball joints. I've looked everywhere on the spindles and all I can find is a "32" cast into one and a "31" cast into the other. Does that denote something ? i'm not sure about that one. see the pic on this page with measurements. that is the A-body spindle 73-76. http://www.allpar.com/history/mopar/brakes/disc-main.html
[Re: krautrock]
#2361449
08/28/17 11:29 PM
08/28/17 11:29 PM
lostdog
mississippi
is there a part number on the spindle? looks like it might be the post 1973 a-body disc brake spindle. the part numbers are 3402626 and 3402627, on the upright of the spindle. if that's the case you just need moog k781 and k783 lower ball joints. I've looked everywhere on the spindles and all I can find is a "32" cast into one and a "31" cast into the other. Does that denote something ? i'm not sure about that one. see the pic on this page with measurements. that is the A-body spindle 73-76. http://www.allpar.com/history/mopar/brakes/disc-main.html It looks like I DO have the later A-body pieces based on the clues that there are no casting numbers, the measurements of the ones I have match the pieces in the article and I have 11" rotors. I'll try the moog k781 and 783 and hopefully that will do it. It looks like someone knew what they were doing and thankfully they did because I do not ! Thank you!
