Re: Brake pedal pressure
[Re: Ply36]
#2360783
08/27/17 08:38 PM
08/27/17 08:38 PM
RapidRobert
that's plenty of clearance, I'm thinking it is something else.
[Re: Andrewh]
#2361049
08/28/17 11:08 AM
08/28/17 11:08 AM
RapidRobert
I would let it idle in your driveway & let it get good & hot & see if they go bad again which would tell you if it is strickly heat related. then you can see about either insulating what needs to be protected or dig in further for the culprit.
