Dana 60 gear selection #2360267
08/26/17 07:24 PM
08/26/17 07:24 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Did they make a 3.91 gear set for the Dana 60 ?
I need a gear change and feel 3.73 is not deep enough for my combo.
Re: Dana 60 gear selection [Re: FastmOp] #2360276
08/26/17 07:32 PM
08/26/17 07:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
To my knowledge, there's nothing between 3.73 and 4.10.
Re: Dana 60 gear selection [Re: FastmOp] #2360292
08/26/17 08:04 PM
08/26/17 08:04 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
3.54 then a 4.10
Re: Dana 60 gear selection [Re: FastmOp] #2360294
08/26/17 08:06 PM
08/26/17 08:06 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I have 3.73 and 3.30 gears. I really need a 3.91 pro gear.
Re: Dana 60 gear selection [Re: FastmOp] #2360346
08/26/17 10:31 PM
08/26/17 10:31 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
try calling Motive Gear they don't show everything they make just a shot in the dark if your 3 73 s are a pro gear and you decide to part with them or motive can help you out let me know I am getting ready to call them to see if they still do those in a pro gear lol
Re: Dana 60 gear selection [Re: FastmOp] #2360368
08/26/17 11:24 PM
08/26/17 11:24 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
My 3.73 are a dana gear not a pro gear.
Re: Dana 60 gear selection [Re: FastmOp] #2360394
08/27/17 12:18 AM
08/27/17 12:18 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have a Motive gear set in my Dana 60 ...It's a 3.90 ratio. Have to use the 4.10-down carrier.
Nautilus Racing-
Re: Dana 60 gear selection [Re: FastmOp] #2360418
08/27/17 01:15 AM
08/27/17 01:15 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Thanks for that info👍
Re: Dana 60 gear selection [Re: FastmOp] #2360878
08/27/17 11:21 PM
08/27/17 11:21 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Shorter tire.. wink
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Dana 60 gear selection [Re: Chris2581] #2361214
08/28/17 04:47 PM
08/28/17 04:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Hmmm? I don't find that in any catalog old or new. Got a part number?
Re: Dana 60 gear selection [Re: FastmOp] #2361260
08/28/17 06:24 PM
08/28/17 06:24 PM
Washington
madscientist Offline
Washington
I've been told some really big fork lifts came with a Dana 60. You may look at fork lift companies and find what you want.
Re: Dana 60 gear selection [Re: madscientist] #2361485
08/29/17 12:13 AM
08/29/17 12:13 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I have heard every year they make a short run of 390 gears for Dana 60s and when they are gone they are gone and they go fast. Not sure if this is true
Re: Dana 60 gear selection [Re: John_Kunkel] #2361491
08/29/17 12:20 AM
08/29/17 12:20 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Got it a few years ago(maybe 3?) Don't know if I still have the carton the gears came in.I went with it because I kept getting the run around for a 4.10 for the 4.56-up carrier that they also had but were out of stock.
Nautilus Racing-
