Re: spring pressure??
[Re: bonefish]
#2359582
08/25/17 12:18 PM
08/25/17 12:18 PM
RapidRobert
I would measure the lbs at the installed height you have on em & the lbs at .060 less than coil bind height. . If it is a dual spring compress it with the retainer on top of the spring. Guys said you can use a drill press and a bathroom scale to get a fairly close number. I started to try it but my garage drill press ain't big enough but I one thing I saw was that you need the spring to be pretty much centered on the scale for a legitemate reading.
[Re: bonefish]
#2359733
08/25/17 04:29 PM
08/25/17 04:29 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Just run one over to the machine shop, it will take only a few minutes to get the RIGHT information. testing a spring without knowing installed height, coil bind,retainer to guide clearance , closed pressure and open pressure is kind of a crap shoot, You wouldnt be giving the buyer any real useful data.A " pressure" doesnt mean a thing really.
RIP Monte Smith
