Anybody use an engine support bar #2357910
08/22/17 12:23 AM
08/22/17 12:23 AM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
I'm looking at swapping motor mounts on my Barracuda with heavy-a$$ hemi. Anybody use an engine support bar that holds the engine supported on a bar with legs that sit on inner fender? Pretty sure my body guy used one when he swapped my k-member for one that wasn't bent.
Re: Anybody use an engine support bar [Re: Vert] #2358062
08/22/17 12:14 PM
08/22/17 12:14 PM
moparx Offline
moparx  Offline
i have built several of these over the years for front drivers, and they work very well. with that being said, it's important to choose material that will support the weight you need to support, plus make the leg "base" as long and wide as possible to support the weight over as large an area as possible. 3/16" material thickness should be more than enough, and for the "cross bar", i would say 1 1/4 or 1 1/2" square tubing would do the job just fine. this would allow your engine to sit there without a transmission being attached. but since you are just changing mounts, why not just use a piece of padded 1/2" plywood under your floor jack to support the engine ? lots less work, and adjustable as you need it.
beer
Re: Anybody use an engine support bar [Re: moparx] #2358134
08/22/17 03:22 PM
08/22/17 03:22 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I used a HF unit when I swapped in my B engine in my 68 Barracuda. It held up flawlessly supporting the engine/trans.
Re: Anybody use an engine support bar [Re: Skeptic] #2358173
08/22/17 05:07 PM
08/22/17 05:07 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
When I was in High School( 72-73 ) I used a couple of 2X4's with a piece of steel(Fender to fender) when I had to replace my K frame in my super bee in pic... Worked fine
Re: Anybody use an engine support bar [Re: minivan] #2358193
08/22/17 05:51 PM
08/22/17 05:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Used the 2x4 method as well. and a ratchet strap
Don't be the exception.
Re: Anybody use an engine support bar [Re: Skeptic] #2358222
08/22/17 06:57 PM
08/22/17 06:57 PM
BDW Online content
BDW  Online Content
What is a "HF unit"?
Engine hoist ?
Re: Anybody use an engine support bar [Re: Vert] #2358241
08/22/17 07:30 PM
08/22/17 07:30 PM
AndyF Offline
AndyF  Offline
HF is probably Harbor Freight.
The last time someone asked this question (earlier this week if I recall) I posted a picture of my bridge crane and said that was how I hold up the engine when changing parts. People thought I was showing off so I won't show the picture this time.
Re: Anybody use an engine support bar [Re: BDW] #2358269
08/22/17 08:15 PM
08/22/17 08:15 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Engine hoist ?
Harbor Freight Link whistling
Re: Anybody use an engine support bar [Re: AndyF] #2358370
08/22/17 11:28 PM
08/22/17 11:28 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Andy, I'd love to have a bridge crane. If you have a link to that previous post I'd appreciate it. I did a search before posting here, but missed that somehow. Thanks to all who mentioned 2x4s and rachet straps. My hemi and trans weigh roughly 900lbs. I have a 4 post lift. I plan to disconnect the headers, lift the engine, and swap from Schumacher mounts to Aruzza mounts. Looks like doing it from the bottom is easier. Not trusting my arms and hands to 2x4s with an engine hanging above them, and the steel beam I gave away years ago cost more than an engine support bar does today. I appreciate the help folks. Seriously!
Re: Anybody use an engine support bar [Re: Vert] #2358376
08/22/17 11:35 PM
08/22/17 11:35 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
Yup
Re: Anybody use an engine support bar [Re: Vert] #2358388
08/22/17 11:52 PM
08/22/17 11:52 PM
BDW Online content
BDW  Online Content
Interesting, no issues with that denting the inner walls or fenders?
Re: Anybody use an engine support bar [Re: UCUDANT] #2358425
08/23/17 01:21 AM
08/23/17 01:21 AM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Originally Posted By UCUDANT
Yup
Exactly what I wanted to see! Thank you!
Re: Anybody use an engine support bar [Re: minivan] #2358444
08/23/17 02:39 AM
08/23/17 02:39 AM
P
Porter67 Offline
Porter67  Offline
P
NOOOOOO!
Re: Anybody use an engine support bar [Re: AndyF] #2358450
08/23/17 03:24 AM
08/23/17 03:24 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Showing off?
Anyone sensible that reads your posts surely knows that you are a smart, yet humble guy. Those that feel different can take a hike.
Re: Anybody use an engine support bar [Re: BDW] #2358556
08/23/17 01:20 PM
08/23/17 01:20 PM
moparx Offline
moparx  Offline
with the base as long as possible, and padded, [plus the legs being high enough to clear the fender tops] there should be no damage incurred.
beer
Re: Anybody use an engine support bar [Re: Porter67] #2358615
08/23/17 03:38 PM
08/23/17 03:38 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Originally Posted By EV2Bird
NOOOOOO!
[quote=minivan] When I was in High School( 72-73 ) I used a couple of 2X4's with a piece of steel(Fender to fender) when I had to replace my K frame in my super bee in pic... Worked fine
[/quot
Re: Anybody use an engine support bar [Re: BDW] #2358764
08/23/17 09:13 PM
08/23/17 09:13 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
No, but I also don't have a Hemi.
Re: Anybody use an engine support bar [Re: Vert] #2358772
08/23/17 09:23 PM
08/23/17 09:23 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
... it also worked great for helping install a FWD trans when I was alone with just a small floor jack
Re: Anybody use an engine support bar [Re: Porter67] #2359218
08/24/17 04:52 PM
08/24/17 04:52 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
NOOOOOO!
YESSSSSS... $700 dollar gas hog in 74.. Nobody wanted them..
Re: Anybody use an engine support bar [Re: minivan] #2359383
08/24/17 10:58 PM
08/24/17 10:58 PM
IN
ahy Offline
ahy  Offline
IN
I have a doubled up 2x4 screwed together with ~8" piece of pine 1 x 2 attached to bear on the seam between the fender and apron for that purpose.
I use it with a 3/8" threaded eyebolt and short length of chain to attach to the rear most hole on a manifold lift plate. Adjust the nut on the eyebolt to set height. No problems with a BB when supporting the engine after transmission removal. I do use a jack and block of wood under the pan while actually pulling the transmission. In part to be able to move it up and down and in part to avoid overloading the engine support.
No damage to the fender... the wood actually rides on top of the fender mount bolts.
