1972 440 HP with LY rods? #2358170
08/22/17 05:01 PM
08/22/17 05:01 PM
New York
R/T1968R/T Offline OP
New York
Picked up a numbers matching 72 Rallye Charger with a 440. Motor had a spun bearing so I tore it apart. Bottom end seems to be original all bearing dates are late 71. the motor has LY rods and not the Six Pack type. I have never seen a 72 HP motor with standard rods, is this common??
Re: 1972 440 HP with LY rods? [Re: R/T1968R/T] #2358171
08/22/17 05:05 PM
08/22/17 05:05 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
I've owned many, all had heavy beam rods
Re: 1972 440 HP with LY rods? [Re: R/T1968R/T] #2358187
08/22/17 05:40 PM
08/22/17 05:40 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Does it have a neutral balancer? If so I would think it was correct. I've bought truck motors with heavy rods and nuetral balancers.
Re: 1972 440 HP with LY rods? [Re: fastmark] #2358229
08/22/17 07:10 PM
08/22/17 07:10 PM
New York
New York
The motor has standard LY rods and the standard neutral balancer
Re: 1972 440 HP with LY rods? [Re: R/T1968R/T] #2358635
08/23/17 04:35 PM
08/23/17 04:35 PM
dogdays Offline
dogdays  Offline
That's what they had that day? Mopar "never say never".
What is the motor assembly date?
R.
Re: 1972 440 HP with LY rods? [Re: dogdays] #2359298
08/24/17 08:22 PM
08/24/17 08:22 PM
New York
New York
Assembly date is 6 28
Re: 1972 440 HP with LY rods? [Re: R/T1968R/T] #2359407
08/24/17 11:39 PM
08/24/17 11:39 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The reason they had to externally balance the 70-71 HP motors is because they had the heavy pistons and heavy rods. Makes since that if they removed the heavy rods and used low compression pistons, it would balance with a neutral balancer.
Re: 1972 440 HP with LY rods? [Re: R/T1968R/T] #2359435
08/25/17 12:55 AM
08/25/17 12:55 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
My '72 440 had LY rods. It had never been apart.
