Big Block Stroker Rods?
#235798
02/25/09 12:57 PM
02/25/09 12:57 PM
Posts: 196 West Central Indiana
Mr.Runum
Looking to build a street/strip motor 451/470 not to radical cam and w/manifolds. Maybe down the road play around with F.A.S.T. My Question is who's rods? Who's rods NOT to use? Cat Oliver Eagle Manley Scat Howards 440 Source Any one eles's to use/not use? Next question. H Beam or I Beam Last Question, for a 470 How Long of a Rod for Street/Strip use? Any advice would be appreciated. Mr.Runum
Re: Big Block Stroker Rods?
[Re: Mr.Runum]
#235799
02/25/09 01:11 PM
02/25/09 01:11 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
In a B motor, a 6.535" rod works really good. 2.2" big end...yeah it's a Chevy style rod, or you can go with a higher pin heigth in the piston and go with a 440 length rod.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: JohnRR]
#235802
02/25/09 01:47 PM
02/25/09 01:47 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I am running Ohio Crankshaft Extreme I-beams. Very nice rod, also available in chevy sizes.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Thumperdart]
#235804
02/25/09 02:31 PM
02/25/09 02:31 PM
Mr.Runum
Any Reason for the short rod? The fact that the Eagles have been good to you is the type of info I am looking for. I was looking at the 3.9, 6.7 1.32 combo. with I Beam Rods.
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
[Re: Mr.Runum]
#235805
02/25/09 03:13 PM
02/25/09 03:13 PM
Thumperdart
State of confusion
This is an old combo that Jason Pettis came up with And if you know Jason, you don`t question his reasoning. It wasn`t something I had input on so that`s all I can tell ya.
[Re: Thumperdart]
#235808
02/25/09 04:15 PM
02/25/09 04:15 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
I`ve got 8+ years on my eagle h beam 6.385 chevy rods w/an off-set ground(3.900) stroke 413 crank in two different combos and they looked/measured great on my last tear down 4 years ago.
What did you use for a PISTON with that combo ?
[Re: Mr.Runum]
#235810
02/26/09 01:14 AM
02/26/09 01:14 AM
Posts: 43,283 Bend,OR USA
Cab_Burge
Which block are you planning on building, low deck or high deck? I have two 440 block motors with 3.9 stroke cranks in them, I used 7.10 long rods in both. One set of Eagles H beam and one set of CAT H beam. I also have a 400 block that has a 4.30 sroke crank in it and I used a CAT 6.80 long H beam steel rod in it, it is four years old now and still going strong after hundreds of runs, 75+ dyno pulls and 1500 to 2200 street mile ( the speedometer deosn't work so I'm not really sure of what the total street miles on it are ) Probally less than I think
