Can someone explain what "core shift" is? #235794
02/25/09 12:51 PM
02/25/09 12:51 PM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
I've heard the term "core shift" a couple of times lately regarding engine blocks. I have never heard of that before. Can someone explain what it is and what causes it?
Re: Can someone explain what "core shift" is? [Re: 6PAX] #235795
02/25/09 01:00 PM
02/25/09 01:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The way I understand it is when things like blocks or intake manifolds are cast, they are cast of molten metal poured into a mold. But something like an intake manifold with have two molds, one for the outside shape and one for the inside shape, then the metal poured in between. The inside mold would be the core. But if the two molds don't stay perfectly aligned through the whole process, you get what's called core shift, because the 'core' has shifted away from where it's supposed to be. I assume that happens because of the cooling process or just from the pouring of the metal.
Someone correct me if I'm wrong.
Re: Can someone explain what "core shift" is? [Re: 6PAX] #235796
02/25/09 01:03 PM
02/25/09 01:03 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
From what I understand, the block is cast and the internal core moves somewhat during casting.... The bore thickness is then different.
Here is a thread with some in depth information on this problem. I know, I know it's a GM site but the info is very good.
Re: Can someone explain what "core shift" is? [Re: DaytonaTurbo] #235797
02/25/09 01:06 PM
02/25/09 01:06 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
The way I understand it is....SNIP...
No correction needed. You nailed it. It dont take much core shift to make a block worthless for an overbore. DaveJ
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
