Re: Recommendations for new distributor and ignition system.
[Re: 70RT Charger]
#2357859
08/21/17 11:01 PM
08/21/17 11:01 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have run one of these Crane set ups for 12 years, on the drag stip and street, my Son has the same in his 547 valiant. We are running MSD dizzy.
http://www.ebay.com.au/itm/CRANE-CAMS-CR6000-6445-HI6-CD-IGNITION-WITH-LX92-COIL-/291146540458?hash=item43c9afa5aa:g:hUAAAMXQuTNTK9fa
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 70RT Charger]
#2357915
08/22/17 12:30 AM
08/22/17 12:30 AM
RapidRobert
good used 70's OE dist, dial in the total (slots) with the FBO $22 plate, the springs, a cap with brass terminals/ribs, check rotor phasing, reduce rotor to cap terminal clearance to 0.015". reduce lower shaft axial play to .005". all this is easier than it sounds. A '75 up OE black HEI module from a junkyard. An Accell super coil, the big yellow beast or a full 12V coil such as the CFD478 at rockauto ($16.02). I cant say it would top a capacitive discharge setup but it runs flawless for me & was cheap.
[Re: ozymaxwedge]
#2357959
08/22/17 01:55 AM
08/22/17 01:55 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Stock Mopar electric distributor recurved, Mopar chrome box, Mopar.25 ohm Ballast and MSD blaster 2 coil. Simple and reliable.
The only Carbs I care about are under the hood!
[Re: TJP]
#2358090
08/22/17 01:21 PM
08/22/17 01:21 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Stock Mopar electric distributor recurved, Mopar chrome box, Mopar.25 ohm Ballast and MSD blaster 2 coil. Simple and reliable. As far the MP box keeps working without a premature fail!
[Re: Dave Hall]
#2358167
08/22/17 04:58 PM
08/22/17 04:58 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just put all the MSD stuff on it you won't be sorry. The MSD Ready-to-Run has adjustable mechanical advance and it's one-piece...no need for additional boxes.
[Re: 70RT Charger]
#2358403
08/23/17 12:40 AM
08/23/17 12:40 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Any magnetic or hall effect dist (or crank trigger) with advance locked out, or a 1977+ Lean Burn Dist. The MSD 6530 Programmable, Digital 6AL-2 ignition box, and a MAP sensor.
With the programmable box, you can dial in the advance curve with a laptop based on load and RPM. Easier, quicker, and more precise than messing with mechanical advance stops, springs and vacuum can adjustments. It also has two programmable rev-limits and retard for N2O or Boost. I haven't tried a lean burn Dist, but the choice of the two pickups may make phasing the dist easier?
[Re: 70RT Charger]
#2358520
08/23/17 12:15 PM
08/23/17 12:15 PM
RapidRobert
I really don't care to spend the money. OE dist (dial in the subsystems)/HEI module (dont forget the heat sink paste)/good full 12V coil. EDIT I was worried about my Rockauto made in china furd coil stranding me but it ain't missed a beat.
[Re: 70RT Charger]
#2358521
08/23/17 12:18 PM
08/23/17 12:18 PM
RapidRobert
Man the choices, figured it'd be easier than this lol Wait till you get into carburetion! (You'll wish you were back here).
[Re: RapidRobert]
#2358522
08/23/17 12:19 PM
08/23/17 12:19 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
I really don't care to spend the money. OE dist (dial in the subsystems)/HEI module (dont forget the heat sink paste)/good full 12V coil. EDIT I was worried about my Rockauto made in china furd coil stranding me but it ain't missed a beat. HEI??? Ok I've heard of HEI in Chevys.
