NHRA rules on tire tubes
#2357547
08/21/17 01:16 PM
08/21/17 01:16 PM
Posts: 1,772 Keymar, MD
DusterKid
Keymar, MD
What is NHRA rules on tire tubes? Do they need to have metal valve stem or not? All I can find about valve stems pertain to TUBELESS tires, nothing about the use of tubes.
5:1 Tires will be visually checked for condition, pressure, etc. and must be considered free of defects by the technical inspector prior to any run. All street tires must have a minimum of 1/16- inch tread depth. Temporary spares, space saver spares, farm implement or trailer tires prohibited. Metal, screw-in valve stems mandatory in tubeless tires, front and rear, on vehicles running 11.99 or quicker; unless OEM tire pressure monitor sensor is used. Chemically treating and physically altering (e.g. lightening, etc.) a tire in any manner is prohibited unless such treatment or alteration is performed by the original manufacturer.
Re: NHRA rules on tire tubes
[Re: DusterKid]
#2357557
08/21/17 01:35 PM
08/21/17 01:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You want the metal ones with tubes.. too easy to have them spin and rip the tubes if you dont have them
[Re: DusterKid]
#2357685
08/21/17 05:12 PM
08/21/17 05:12 PM
Challenger 1
Cincinnati, Ohio
Rear slicks..I've been running rubber vale stem tubes for years with bead screws and haven't had a issue "knock on wood'. At the track yesterday a fellow racer told me I needed metal valve stems per the rule book. Just wanted to clarify if it is indeed a rule, since I couldn't find it in the rulebook. Metal valve stem in the wheel for tubeless tires is all I know. I would try to run tubeless, they are a PIA and weigh too much...tubes. Why tubes?
[Re: Challenger 1]
#2357704
08/21/17 05:36 PM
08/21/17 05:36 PM
MR_P_BODY
Rear slicks..I've been running rubber vale stem tubes for years with bead screws and haven't had a issue "knock on wood'. At the track yesterday a fellow racer told me I needed metal valve stems per the rule book. Just wanted to clarify if it is indeed a rule, since I couldn't find it in the rulebook. Metal valve stem in the wheel for tubeless tires is all I know. I would try to run tubeless, they are a PIA and weigh too much...tubes. Why tubes? I got sick and tired of airing up my slicks every other day without the tubes.. I soaped them up I think 4 times.. with the tubes.. never did again plus the tubes made the car hook much better
[Re: dvw]
#2357761
08/21/17 07:43 PM
08/21/17 07:43 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My M/T's will hold air for over 6 months with the sidewalls soaped. That being said I'm going to try tubes to stiffen them up at the next pair of tires. Doug I can go all Winter without adding air to my M/T slicks. When new I mix up Dawn and a little water and totally coat the inside of both slicks. I let it dry for a couple of hours and repete. I used to see them leaking around the screws but now that I use HighTac to glue them on they never leak. The screws were pushing the slicks away from the rim even after I drilled into the slick.
[Re: DusterKid]
#2357897
08/22/17 12:03 AM
08/22/17 12:03 AM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A proper racing tube typically has a metal valve that clamps to the wheel. Not cheap.
