ET difference going from bias tire to radial #2356504
08/19/17 12:21 PM
08/19/17 12:21 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Will need new tires after season
If i swap 28by 10 bias slick to the same size radial( assuming the car continues to hook well) any difference on the slip?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: ET difference going from bias tire to radial [Re: B3422W5] #2356507
08/19/17 12:22 PM
08/19/17 12:22 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Most say a tenth or better faster on the radial.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: ET difference going from bias tire to radial [Re: an8sec70cuda] #2356518
08/19/17 12:44 PM
08/19/17 12:44 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Mine ran .15 quicker with Radials.
Re: ET difference going from bias tire to radial [Re: DblOJoe] #2356566
08/19/17 02:04 PM
08/19/17 02:04 PM
I've seen from .10 to .18 decrease in ET in the 1/4 mile depending on the power of the car and weather conditions, slower cars gain less than the higher HP cars do shruggy
Re: ET difference going from bias tire to radial [Re: B3422W5] #2356574
08/19/17 02:13 PM
08/19/17 02:13 PM
Locomotion Offline
Locomotion  Offline
Your finish line rpm's will likely increase because radial slicks don't grow like bias ply slicks.
Re: ET difference going from bias tire to radial [Re: B3422W5] #2356575
08/19/17 02:18 PM
08/19/17 02:18 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My car didn't gain much but I think it was needing the growth from the bias tire as I am pretty tapped on gear at the moment. What did surprise me is that my 60ft went down by .05 and I didn't have a traction problem. I log driveshaft speed and while there was maybe some slip with the bias tire it wasn't much. The radial shows a smooth graph with zero tire slip.
I went from a 28x10.5S slick to a 28x10.5 pro bracket radial. I didn't run many passes on the bias tire but I am a big radial fan. But just like you see everyone say when the track is marginal so is the radial.
68 Barracuda Formula S 340
Re: ET difference going from bias tire to radial [Re: B3422W5] #2356581
08/19/17 02:34 PM
08/19/17 02:34 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
The radial is 87 i want to run, my bias ply is 88. Want a bit more gear so it might help on that a bit.
1.41 best 60 foot
6.56 at 104.17
Re: ET difference going from bias tire to radial [Re: B3422W5] #2356705
08/19/17 06:50 PM
08/19/17 06:50 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Don,
Are you thinking radial slick or a dot drag radial? Some classes require a dot tire, just wondering if that's what you're thinking?
Re: ET difference going from bias tire to radial [Re: B3422W5] #2356723
08/19/17 07:23 PM
08/19/17 07:23 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
DOT radial. Hoosier 275 like i had on my white Duster.
1.41 best 60 foot
6.56 at 104.17
Re: ET difference going from bias tire to radial [Re: DblOJoe] #2356876
08/19/17 11:58 PM
08/19/17 11:58 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Im shocked. So from what slick to what radial ? I am fitting some 275/60/15 M/T Pro Radials now and was expecting to run a touch slower than on the 28" slick.
1963 Plymouth Max Wedge
1971 Barracuda
Re: ET difference going from bias tire to radial [Re: ozymaxwedge] #2356902
08/20/17 01:16 AM
08/20/17 01:16 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Im shocked. So from what slick to what radial ? I am fitting some 275/60/15 M/T Pro Radials now and was expecting to run a touch slower ythan on the 28" slick.
Al,
If you havent bought yet look at the pro bracket radial. Is lighter than pro275 . I had major balance issues with pro275 as well . I am on my second set of pbr 28x10.5r15 . 150 plus passes first set , still have 5-20 left when swapped out
Oh i have only ever run radials on the satellite
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: ET difference going from bias tire to radial [Re: B3422W5] #2356904
08/20/17 01:23 AM
08/20/17 01:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I switched from a Hoosier QTP bias tire of 29.5 x 11.5 to the 30 x 9 Hoosier radial slick. I switched when I had my old 440 in my 63 which ran mid 11's. I did not notice any change in my et but I like the car with the radial slicks as it handles better and has no wondering on the top end at all. Course I run more air pressure in the radials which may be helping it to go nice and straight also as I run about 18 psi in my radials when racing. And I found as long as I stage in the grove where everyone is launching it is very consisdent on the radial slicks. Cant say for sure if my car is any faster on radials but I like them much better then the bias and will not go back to the bias. I have only run the radials with my 493 and they work real good behind my 493 as it always hooks fine as long as I stage in the grove. Ron
Re: ET difference going from bias tire to radial [Re: ozymaxwedge] #2356914
08/20/17 01:40 AM
08/20/17 01:40 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Went from a Hoosier 30x9 bias slick to a 30x10.5 Hoosier radial slick.
Re: ET difference going from bias tire to radial [Re: DblOJoe] #2357269
08/20/17 08:41 PM
08/20/17 08:41 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I tried M/T 29.5/10.5w and M/T 315/60 Drag Radial on the same night at Test and Tune and ran .11 quicker in the 1/8 with the Drag Radials on my D-50. I was running in the 6.30 range at the time. I will never buy a slick again.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
