2014 Avenger Throttle body replacemnt. Relearn procedeure? #2356591
08/19/17 02:49 PM
08/19/17 02:49 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Dealer wants over $600 to replace the throttle body ( its my sisters car )
I can a get a new Mopar TB for under $250 and put it on myself.
Can anyone tell me if I HAVE to take it back to the dealer to have this so called relearn procedure done?
Re: 2014 Avenger Throttle body replacemnt. Relearn procedeure? [Re: gtx6970] #2356654
08/19/17 05:11 PM
08/19/17 05:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
On the Ram all I had to do was depress the gas pedal three times slowly with the key on but not started.
Re: 2014 Avenger Throttle body replacemnt. Relearn procedeure? [Re: stumpy] #2356698
08/19/17 06:36 PM
08/19/17 06:36 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks,
I found a procedure similar to that online.( google is your friend )
Worked like a charm.
