Bent axles...wobbly wheels #2356252
08/18/17 09:54 PM
08/18/17 09:54 PM
an8sec70cuda Online content OP
an8sec70cuda  Online Content OP
So I noticed my rear wheels were wobbling a little at low speeds, could actually feel it while rolling down main street. Jack up the car, both sides do it the same. Remove tires, see axle flange is doing the wobbling. So apparently my axles are bent.
These are 35 spline Mosers in a Dana 60. They are 14 years old...Moser has a 10 year warranty.
Really hope the housing isn't bent too.
Anyone else had this happen?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356278
08/18/17 10:36 PM
08/18/17 10:36 PM
Washington
madscientist Offline
Washington
Yep. 35 spline Strange in about 1990.
I bought Sumers brother 40 spline and was done with it.
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356288
08/18/17 11:03 PM
08/18/17 11:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I havent bent mine but they are twisted at
the base.. that happened within a dozen passes
but never got any worse..they have about a single
spline of twist... these are Strange 35
wave
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356289
08/18/17 11:11 PM
08/18/17 11:11 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Axles twist. Flanges bend. Part of life. You might limit it by going to 40 spline, but you know at some point you will turn up the power even more, and eventually bend and twist those. If you think all those years of 8,9 and 10 second passes in a 3,500+ lb car doesn't take it toll, guess again. My opinion. Get another set of axles and just keep going.
[image][/image]
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356304
08/18/17 11:48 PM
08/18/17 11:48 PM
I've seen splines twisted and axles sheared off, but not bent flanges like this.
CHIP
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356306
08/18/17 11:49 PM
08/18/17 11:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have some guys with heavy, fast stick cars. When the guy at Mark Williams says "I've been here 15 years and never seen that." you know anything can be bent or broken. 35 spline axles have their limits.
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356344
08/19/17 12:59 AM
08/19/17 12:59 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Stock axles in Challenger were bent. I dont think moser or strange are really that much stronger that stock dana axles
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356357
08/19/17 01:28 AM
08/19/17 01:28 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Moser and the cheaper Strange axles are similar. The Strange race axles, not so much I don't believe.
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356434
08/19/17 09:00 AM
08/19/17 09:00 AM
sgcuda Offline
sgcuda  Offline
The flange itself doesn't bend. It bends at the base of the shaft. You have a real powerful, heavy car. If the tires bite hard enough, something has to give. Truth be told, you probably need a larger diameter shaft (ie: 40 spline). But that's a lot to change up. If you can get another set of axles to outlive the warranty, what's wrong with that?
[image][/image]
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356441
08/19/17 09:29 AM
08/19/17 09:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The extra torque that comes out of that blue bottle probably did this haha.
Would a 40 spline be any larger between the flange and the bearing?
68 Barracuda Formula S 340
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356449
08/19/17 09:59 AM
08/19/17 09:59 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The joys of Drag Radials.
69 GTX 68 Road Runner
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356462
08/19/17 10:35 AM
08/19/17 10:35 AM
I understand the shaft is bent near the flange, guess i should have worded it differently. It'd be kinda hard to bend the flange itself.
Fwiw...I've seen a lot of broken Strange products, but not Moser or MW. Even had 2 friends switch to Moser after Strange axle failures and have no more trouble.
Yeah, nitrous and drag radials definitely take a toll on things. Guess i never figured I'd be in this ballpark with this car, lol.
If i went 40 spline, will it work with the stock housing ends?
CHIP
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356469
08/19/17 10:58 AM
08/19/17 10:58 AM
tboomer Offline
tboomer  Offline
Chip...Its that big ol Hemi! wave
Re: Bent axles...wobbly wheels [Re: CMcAllister] #2356471
08/19/17 11:06 AM
08/19/17 11:06 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
iagree
That is correct, Moser axles are not much stronger than stock.
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356472
08/19/17 11:07 AM
08/19/17 11:07 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Have had several different axle flanges out of round. A couple were that way brand new. I use a dial indicator to measure the amount of run out. And then glue feeler guages the right thickness between the flange and drum to true it back up. Have run that way for years with no problems. I have one side shimmed on my Cuda now.
twocents
Master, again and still
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356475
08/19/17 11:12 AM
08/19/17 11:12 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I think you need big Ford ends for 40 spline axles.
Re: Bent axles...wobbly wheels [Re: JERICOGTX] #2356483
08/19/17 11:37 AM
08/19/17 11:37 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Std Mopar ends have a 2.875 bearing bore. 40 spline axles take 3.150 bearings. That being said I think Mark Williams makes a Mopar end for the 3.150 bearing. Radials find all the weak links.
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356561
08/19/17 01:54 PM
08/19/17 01:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I wrote a few calculations wrt axle size here: http://victorylibrary.com/mopar/axle-spline.htm
As you see, 35 > 40 is a really big help.
Boffin Emeritus
Re: Bent axles...wobbly wheels [Re: an8sec70cuda] #2356648
08/19/17 04:53 PM
08/19/17 04:53 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Going to 40 spline stuff may require a different case with a larger 3.250 side bearing. Not enough room in the smaller bore for the axle, spool and bearing. Sometimes it just makes sense to step up to the good stuff to begin with. Gun drilled 40s are lighter than solid 35s and substantially stronger.
Re: Bent axles...wobbly wheels [Re: CMcAllister] #2356662
08/19/17 05:35 PM
08/19/17 05:35 PM
Cincinnati, Ohio
Cincinnati, Ohio
Big investment to go to a 40 spline I bet for your car. I think a better quality 35 spline Axle from Mark Williams or Strange would do the job for you.
Did you ever use wheel spacers?
MW 40 spline gun grilled floater axle out of my top alcohol dragster.
Do you really think 40 spline is necessary in the OP situation?
