1970 B Body Door to Wing Window Channel Fuzzies Installation #2356276
08/18/17 10:34 PM
08/18/17 10:34 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Hey guys,
I asked this question in the general section and got no answers. I am installing the fuzzy strips that attach to the door glass and fit into the wing window channels and slide up and down with the glass. How do I go about punching holes for the H shaped nylon sliders? do I leave any excess fuzzy material above or below the window glass? where do I trim it? the glass has an edge cut off at the top, I presume to fit into the upper rubber seal.
Any help and pictures would be appreciated. I have an original mopar set of fuzzies and I don't want to screw them up.
I’m listening.
Re: 1970 B Body Door to Wing Window Channel Fuzzies Installation [Re: Big Bad Bee] #2356628
08/19/17 03:55 PM
08/19/17 03:55 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
This installation is covered step by step in the Car Tech Book
Mopar B-Body Restoration 1966 -1970. It is available on Amazon.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 1970 B Body Door to Wing Window Channel Fuzzies Installation [Re: Big Bad Bee] #2356739
08/19/17 07:47 PM
08/19/17 07:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 1970 B Body Door to Wing Window Channel Fuzzies Installation [Re: Big Bad Bee] #2356811
08/19/17 09:21 PM
08/19/17 09:21 PM
Canada
demon Offline
demon  Offline
Canada
I use a soldering iron to make the holes.
And the white clips that Chrysler includes with the fuzzies are too big. So reuse your old ones or file the new ones down.
Re: 1970 B Body Door to Wing Window Channel Fuzzies Installation [Re: demon] #2357813
08/21/17 09:43 PM
08/21/17 09:43 PM
Spokane Valley, WA
Spokane Valley, WA
Thank you for the suggestions. Was trying to get the car ready for a show and was out to time ordering books. Mike that link is great for the disassembly but says to follow the FSM for reinstallation... The FSM says nothing about how to install the fuzzy pieces, but I've looked at enough photos and blogs to figure it out. The soldering iron tip is a really good idea. Could burn the holes while in place on the glass. I used a hole punch but had to try twice. Thank you for the info on filing down the guides. I've got the pieces cut and ready to go in once the guides are ready.
The FSM says to mount the lift bracket and insert the plastic rivet before putting the window in. I'm here to tell you, it ain't going to fit through the top of the door edge. somebody was a sleep at chrysler engineering.
I’m listening.
Re: 1970 B Body Door to Wing Window Channel Fuzzies Installation [Re: Big Bad Bee] #2358180
08/22/17 05:25 PM
08/22/17 05:25 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Those fuzzies are major SPENDY from Chrysler (if still available) . . . I bought new set and ended up using half new and half original on my 70 Sport Satellite ! Guess you got the engine running !!! YAHOO !!!
Re: 1970 B Body Door to Wing Window Channel Fuzzies Installation [Re: Big Bad Bee] #2359029
08/24/17 10:37 AM
08/24/17 10:37 AM
MI
MI Mopar Works Offline
MI
The lift bracket and rivet absolutely will fit through the top of the door opening. The trick is to not have the cat whiskers/window sweeps installed yet.
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: 1970 B Body Door to Wing Window Channel Fuzzies Installation [Re: MI Mopar Works] #2359324
08/24/17 09:09 PM
08/24/17 09:09 PM
Canada
demon Offline
demon  Offline
Canada
Yes, I have done it many times.
Another method of changing the vertical fuzzy is to remove the screw and rubber seal at the top of the vent channel, and carefully spread the channel back from the vent window frame. This will allow you to slide the glass out and back in from the top and not disturb the vent frame adjustment.
