Re: Brake Drum External Spring
[Re: Morty426]
#2356273
08/18/17 10:30 PM
08/18/17 10:30 PM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
Winner......tap a brake drum with and without the spring with a wrench or similar steel object and you'll hear the difference. Or spin the drum with and without the spring and while it's spinning touch the wrench or screwdriver to the spinning drum..again you'll hear the difference. MikeR
[Re: A12]
#2356515
08/19/17 12:36 PM
08/19/17 12:36 PM
Posts: 567 Indianapolis, IN
B5Cuda440-6
Indianapolis, IN
Winner......tap a brake drum with and without the spring with a wrench or similar steel object and you'll hear the difference. Or spin the drum with and without the spring and while it's spinning touch the wrench or screwdriver to the spinning drum..again you'll hear the difference. MikeR That makes total sense. It's a harmonic dampener.
[Re: 71birdJ68]
#2356534
08/19/17 01:08 PM
08/19/17 01:08 PM
Posts: 2,091 New Mexico
JMCFAN
New Mexico
It's for if you push too hard on the brake and expand the drum. The spring will bring it back to the right size. LOL
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
