Re: 4 speed guru's please read!
[Re: moparrush]
#235602
02/25/09 10:00 AM
02/25/09 10:00 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I got the parts from a transmission specialty supply house who deals in nothing but transmissions.
But did they give you the RIGHT bearing ? there is a specific bearing for the 833 , there are also others that are the same number , but the wrong suffix and that could cause the problem you see , plus most of the bearings are now sourced from china and it would not surprise if they made it wrong.
[Re: JohnRR]
#235604
02/25/09 10:12 AM
02/25/09 10:12 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
So, you are saying the bearaing sits flush to the case but sticks out too much?
i had a sorta similar problem once when I installed an oil slinger in a case that wasn;t originally equipped with one, but I can't remember the exact details, been about 6 years.
[Re: tecmopar]
#235605
02/25/09 10:44 AM
02/25/09 10:44 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Most times when this happens its the large snap ring that comes with the bearing, its to thick. If you still have the old one, try it.
I agree, most likely the snap ring
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
