Cleaning taillight lenses #2355654
08/17/17 08:39 PM
08/17/17 08:39 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I bought some Duster taillight lenses at the Nats that were all goobed up with some sort of black tar-like substance around the edges. Apparently someone in the past had tried to seal a trunk leak. I was able to get most of it off just by pulling it off but there is some left that is smeared on the lenses. I would like to know if anyone can recommend what I could use to clean it off that won't tarnish or otherwise harm the plastic lenses. Thanks.
Re: Cleaning taillight lenses [Re: 1970RT] #2355686
08/17/17 09:25 PM
08/17/17 09:25 PM
IN
ahy Offline
ahy  Offline
IN
Some common paint thinner may help. After, I have found that common polishing compound works quite well on plastic lenses. I start with the polishing compound then use the plastic sealer in the Eastwood plastic polishing kit to finish.
Re: Cleaning taillight lenses [Re: 1970RT] #2355816
08/18/17 12:30 AM
08/18/17 12:30 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
mothers mag wheel polish works well
Re: Cleaning taillight lenses [Re: 1970RT] #2355845
08/18/17 01:52 AM
08/18/17 01:52 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I would caution using any solvent such as paint thinner on plastic, it likely will damage the plastic..
Just my $0.02... wink
Re: Cleaning taillight lenses [Re: 1970RT] #2355851
08/18/17 01:58 AM
08/18/17 01:58 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Use an Orange Citrus cleaner to get off the goo
Re: Cleaning taillight lenses [Re: 1970RT] #2355895
08/18/17 04:53 AM
08/18/17 04:53 AM
Pledge liquid or spray furnish polish works very well on Lexan airplanes windows up scope
I've used it on several old faded tail lights and they look a lot better now than before up
Re: Cleaning taillight lenses [Re: Cab_Burge] #2355948
08/18/17 11:13 AM
08/18/17 11:13 AM
moparx Offline
moparx  Offline
some plain old kerosene or wd-40 might also work. i believe neither will damage the plastic.
beer
Re: Cleaning taillight lenses [Re: 1970RT] #2356016
08/18/17 01:09 PM
08/18/17 01:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Toothpaste is soft enough even to get lense polished.
Stock lenses won't be damaged by thiner or kerosene. Can't talk about repros. I'd try kerosene since won't evaporate inmediatly. Then finish the cleaning with toothpaste
Re: Cleaning taillight lenses [Re: 1970RT] #2357700
08/21/17 05:31 PM
08/21/17 05:31 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Try Bonami cleanser. It works. or Flitz polish
