498 Trick Flow Head Carb Tuning #2355716
08/17/17 09:59 PM
08/17/17 09:59 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
1972 Satellite
Weight was 3200 with driver old combo (440 iron headed, filled with hard block. So little lighter now
New engine B block eagle 4.15 stroker kit 11.1 compression
Out of the box trick flows 240 for roller cam
Harland Sharp rocker arms 1.7 (thanks AndyF)
Comp Roller Cam (thanks fast68plymouth) around 268 dur and 690 lift.
High volume pump with jeg cheap pan and milodon pickup (thats a whole different story)
Trick flow intake out of the box.
950 holley unknown anything about it
MP distributor
super comp headers, open exhaust
8" ptc converter
4.1 gear
ladder bar car
transbrake
4 passes on new gear, converter and engine
No timing changes and little rich by looking at plugs
Passes made yesterday at Byron, il
Best pass was 10.214 at 131.04
Jets
82 front 3.5PV POWER VALVE IS BAD!!!!!!!!!!!
85 rear plugged
Copying some info fromm the 600 hp thread
Here is metering block info. This was never driving on street, was not impressive at tip in around the pit and short drives. Will get exhaust welded up soon.
Knowing the power valve is bad I have a new 2.5 sitting in garage.
What jet change should I make?
Can pick up different power valve tomorrow after work. Idle before vacuum guage was around 5-7 but jumpy and real senstive to idle screws, idle best around 3/4 turn out. I have no partial throttle info.
outer air bleeds are .069
inner air bleeds are .030
Plugs after run and driving back to trailer.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355745
08/17/17 10:32 PM
08/17/17 10:32 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
The .088" on the e holes is wrong. Look deeper inside, you'll see a smaller drill hole in each one.
[image][/image]
Re: 498 Trick Flow Head Carb Tuning [Re: sgcuda] #2355769
08/17/17 11:02 PM
08/17/17 11:02 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree. they should be more like .026"
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355809
08/18/17 12:22 AM
08/18/17 12:22 AM
Cab_Burge Online work
Cab_Burge  Online Work
Fix what is wrong first before changing anything else up
Changing one thing at a time will get you far better results than two or three things at once up work
What plug numbers are you using?
How much total timing are you running now?
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355839
08/18/17 01:34 AM
08/18/17 01:34 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Sorry for typo on that, fixed it to be the .028
Good Catch!!!
I want to fix the power valve but think I should change the jetting to match. Think it was bad since i owned it.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355855
08/18/17 02:14 AM
08/18/17 02:14 AM
AndyF Offline
AndyF  Offline
I wouldn't use a super soft power valve like 2.5 or 3.5 in a street car. If it was me I'd put a 6 or 6.5 in it and see how it works. Idle vacuum doesn't really matter, the power valve doesn't work at idle it works when the engine gets loaded at higher RPM. Put a vacuum gauge in the car and see what it says when you are cruising down the freeway. It will probably be 13 or 15 or something in that range. If that is the case then a 6 or 6.5 should be fine.
82 jets up front are probably too large but hard to tell without some data. See if you can find a model number on the carb and then jet it like stock. You'll probably want something like a 75 jet + power valve up front and maybe 85 with no power valve out back. Hard to say without knowing more about the carb though.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355916
08/18/17 09:27 AM
08/18/17 09:27 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Carb is 80496 will dig up the factory jetting.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355917
08/18/17 09:28 AM
08/18/17 09:28 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Edit to show holley stock jetting
I will pick up a 6.5 power valve today, change the front jets to 79 and leave the rear at 85
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355945
08/18/17 11:02 AM
08/18/17 11:02 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Plugs are
Autolite # 3924
Timing at 34 degrees total with mechanical kicked in. Can not remember where its at initial.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355974
08/18/17 11:47 AM
08/18/17 11:47 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
factory 79/79 jetting ?
does it have secondary power valve?
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2355986
08/18/17 12:21 PM
08/18/17 12:21 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Assuming factory it does. My carb does not have a secondary power valve
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2356028
08/18/17 01:26 PM
08/18/17 01:26 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Do yourself a favor....... Buy an A/F ratio gauge.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2356036
08/18/17 01:42 PM
08/18/17 01:42 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
A/f Gauge is on the list, need some exhaust also. Going broke with this car runaway
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2357058
08/20/17 12:34 PM
08/20/17 12:34 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Changed front jet to 79, replaced power valve with a 5.5, same DA as last week differnt track. Cordova Il
Ran 10.1 at 131-132
Will post a video later today
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2357066
08/20/17 12:58 PM
08/20/17 12:58 PM
AndyF Offline
AndyF  Offline
Sounds like you are making pretty good power. Should be a fun ride at 132 mph. Keep an eye on the plugs if you don't have an AF gauge.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2357091
08/20/17 01:36 PM
08/20/17 01:36 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Was checking the plugs and could lean down more, I was hoping the weather would cool off and hit that 9.99. Will see what next weekend does.
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2357197
08/20/17 06:00 PM
08/20/17 06:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What is your complete tune now? Do you have an 80496 with pressed-in idle & main air bleeds, or 80496-1 with screw-in bleeds?
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2357339
08/20/17 11:38 PM
08/20/17 11:38 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Pressed in idle & air bleeds
Jets
79 front 5.5PV
85 rear plugged
Timing still at 34
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2357392
08/21/17 01:25 AM
08/21/17 01:25 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Check timing with a different light...looks like mark is very close to the thread...you could be of buy a couple degrees.or even more ...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 498 Trick Flow Head Carb Tuning [Re: Dart451] #2357479
08/21/17 10:58 AM
08/21/17 10:58 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Will double check timing tonight
