Support engine after trans removal #2355193
08/17/17 12:05 AM
08/17/17 12:05 AM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Its been many years since I pulled a trans without the engine. Are motor mounts enough to support the engine, or do I need to fabricate a support for the rear of the engine?
Re: Support engine after trans removal [Re: Vert] #2355198
08/17/17 12:10 AM
08/17/17 12:10 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
You could wrap a rag around a short piece of appropriate size wood block and set it between oil pan and centerlink usually.
Re: Support engine after trans removal [Re: Vert] #2355373
08/17/17 11:30 AM
08/17/17 11:30 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Assuming the car will not be moved?
Blocks of wood
Jack
car stands
Re: Support engine after trans removal [Re: floridian] #2355376
08/17/17 11:38 AM
08/17/17 11:38 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If the exhaust is still on it, wrap straps around the exhaust pipes, and then around the torsion bars.
Re: Support engine after trans removal [Re: floridian] #2355379
08/17/17 11:39 AM
08/17/17 11:39 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i usally unbolt the trans from the cross mount then let it drop a couple o inches then block the engine with 4x4 or 2x4 wood then remove the trans.it makes it eaisier to put back in IMO, your results may vary.
Re: Support engine after trans removal [Re: Vert] #2355380
08/17/17 11:40 AM
08/17/17 11:40 AM
an8sec70cuda Offline
The factory style motor mounts should be able to hold the motor up, but I'd use a small block of wood b/t the oil pan and drag link to hold it up.
If the exhaust system is still hooked up, then you really don't need to block of wood. The motor mounts hold the weight of the motor, the exhaust will just keep it from trying to tip backwards.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Support engine after trans removal [Re: an8sec70cuda] #2355434
08/17/17 01:23 PM
08/17/17 01:23 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I have to remove the trans in the 69 Dart this w/e. I always pop the distributor cap off too since it will get close to the firewall on an A body. I used the 73 up spool mount K frame and a 2x4 setting on the drag link is almost perfect when the trans is removed. twocents
...FAFO...
Re: Support engine after trans removal [Re: skicker] #2355519
08/17/17 03:50 PM
08/17/17 03:50 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Small jack out of daily driver and a block of wood.
Re: Support engine after trans removal [Re: buildanother] #2355582
08/17/17 05:55 PM
08/17/17 05:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's how I do it; while the engine mounts might hold the engine, you'll stress them past their normal limits...they fail often enough as it is.
Re: Support engine after trans removal [Re: Vert] #2355648
08/17/17 08:28 PM
08/17/17 08:28 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
A few years back I came up with a simple support to shift the pressure onto the rails and block. Less chance of distorting the pan this way. It's set up so it can be used with the jack as well as a long term support with jack stands or steering link.
Rear-engine-support-MVC-655F.jpgRear-engine-support-MVC-653F.jpgrear engine jack adapter 1.jpg
Re: Support engine after trans removal [Re: Mattax] #2355653
08/17/17 08:37 PM
08/17/17 08:37 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I just keep it simple.
Bolts (seen screw drivers used) through the lower mounting holes in the block and a 2X4, even a broom handle has worked, across the torsion bars. Rest bolts on top of 2X4 and everything is solid.
Car can be moved and the motors stays put.
I have mechanical Aptitude.
I can screw up anything.
Re: Support engine after trans removal [Re: floridian] #2355680
08/17/17 09:11 PM
08/17/17 09:11 PM
IN
ahy Offline
ahy  Offline
IN
Blocks of wood
Jack
car stands
My solution also... with non-hydraulic jack so it does not creep down. It is possible to rig supports between the T bars also... always with a block of wood between the back of the oil pan any any steel supporting it.
Re: Support engine after trans removal [Re: Vert] #2356025
08/18/17 01:22 PM
08/18/17 01:22 PM
AndyF Offline
AndyF  Offline
I just use the bridge crane to hold the engine up while I'm working on the trans.
Re: Support engine after trans removal [Re: Vert] #2356033
08/18/17 01:39 PM
08/18/17 01:39 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Show-off!!LOL
Joe
