60amp to 120amp Denso swap with AREngineering bracketry #2355403
08/17/17 12:11 PM
08/17/17 12:11 PM
Saskatchewan
TWAMONACO Offline OP
Saskatchewan
I made an error when I ordered the AREngineering 60 amp Denso alternator bracketry kit as a 60 amp alternator will not provide enough amperage for my car (440 engine).
What is the experience on using the AREngineering bracketry with a higher output (120 amp) Denso style alternator? Part numbers would be appreciated
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355437
08/17/17 01:32 PM
08/17/17 01:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This alternator looks identical but is 120 amps. Should be a direct fit with the ARE brackets. The link is just for reference photos. Before I spent the money I'd take the 60 amp in with me to a parts store and compare the two side by side.
http://www.ebay.com/itm/HIGH-OUTPUT-ALTERNATOR-Fits-TOYOTA-T-100-PICKUP-4RUNNER-3-0L-V6-1993-1995-120AMP/251195938420?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: Stanton] #2355485
08/17/17 03:01 PM
08/17/17 03:01 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
It works, I have that setup on my 383.
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355509
08/17/17 03:37 PM
08/17/17 03:37 PM
None
71rm23 Offline
71rm23  Offline
None
For part numbers, go to ARE's site. Either order from there or there is dealers that sell his stuff
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: 71rm23] #2355538
08/17/17 04:38 PM
08/17/17 04:38 PM
Saskatchewan
Saskatchewan
At one time there was a 120 amp kit offered, but now they (Mancini, Hughes) only offer the 60 amp kit; if someone had bought that 120 amp kit and had the Denso number off the Alternator that would be the ticket. AREngineerings website doesn't list a phone number or email address.
I looked at the one on EBay as above, but on the cross reverence alternates it lists they are 60 amp units so I would suspect that it's still a 60 amp one.
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355544
08/17/17 04:52 PM
08/17/17 04:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What, so you don't believe this part ...
>>>>HIGH OUTPUT 120 AMP<<<<
MPR: WAI
ROTATION: CW
REGULATOR: I/R
AMPERAGE: 120 AMP
VOLTAGE: 12-14.7 VOLT
PULLEY: 4-GROOVE OVERDRIVE PULLEY
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355565
08/17/17 05:33 PM
08/17/17 05:33 PM
Saskatchewan
Saskatchewan
It just concerns me that they are listing it as an alternative to the 60 amp part numbers - I am probably just overthinking it - Thanks for the suggestions
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355618
08/17/17 07:31 PM
08/17/17 07:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's right, a 120 amp alternative ... which is exactly what you want, right ?!?!?
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355639
08/17/17 08:14 PM
08/17/17 08:14 PM
AndyF Online content
AndyF  Online Content
The 120 amp kit was totally different. It used a much larger alternator and the alternator was low mounted. I stopped selling the 120 amp kit since it was a pain to build and some customers tried mounting it into cars that it wouldn't fit in (A body).
The 60 amp kit is fairly fool proof and 60 amps is enough output for almost everyone. 60 amp Denso alternators are OEM on a lot of vehicles. My wife's SUV has a 60 amp alternator on it and that rig is EFI, heated seats, electric defrost, stereo, AC, dual heaters, etc.
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355703
08/17/17 09:46 PM
08/17/17 09:46 PM
Saskatchewan
Saskatchewan
Thanks Andy - the car is bone stock, no fancy stereo, A/C or electric fuel pump, just upgrading to 6AL ignition (which calls for 0.9 Amps per 1000RPM) and an electric cooling fan which calls for 22 peak amps
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: AndyF] #2355704
08/17/17 09:47 PM
08/17/17 09:47 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That's funny Andy, I bought one of the 120 Amp kits and put it in my B engine'd A body. It fits, but it's tight in there- but everything's tight in a Big Block A body. Not a great picture, but the best one I have right now. The output stud is close to the RPM head and the plastic piece on the stud had to be removed. I replaced your supplied hardware with the buttonhead allen bolts, soon to be replaced with ARP stainless 12 pnt hardware.
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: Stanton] #2355710
08/17/17 09:53 PM
08/17/17 09:53 PM
N
N
denso 2100138
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: Nukechargerboy] #2355762
08/17/17 10:57 PM
08/17/17 10:57 PM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
I got a slightly used Denso 120 amp unit over on BigBlock Dart.com several years ago, ordered this bracket from Mancini
Tight fit between the head and alt... but looks like it will work for my big block A body Cuda
He told me it was a John Deere application
Cuda Engine pics Aug 2017 (1).jpgCuda Engine pics Aug 2017 (3).jpgCuda Engine pics Aug 2017 (4).jpgCuda Engine pics Aug 2017 (8).jpg
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: DonnieLawson] #2355797
08/17/17 11:52 PM
08/17/17 11:52 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Be careful those pulley grooves are way too large for a pass car belt, you will probably need to swap over a different pulley. My alt in the picture was off of a '91 d3500 with a Cummins. twocents
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355852
08/18/17 02:09 AM
08/18/17 02:09 AM
I made a few kits using a big alternator from a Lexus SUV. That was a nice kit and the alternator was super bulletproof. But the combo was way to expensive to sell to Mopar guys so we killed it. I might put one on my own car though since it was a cool setup.
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2355984
08/18/17 12:11 PM
08/18/17 12:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm wondering what makes an alternator "a cool setup" !!!
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2356282
08/18/17 10:54 PM
08/18/17 10:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use a 60 amp Denso alt that I snagged off of a cash for clunkers 89 Yota 4 cylinder pick-up on my car and it works perfectly. Even when I was running an electric water pump,fan,fuel pump,and an MSD 6AL and it never skipped a beat even at 6000 RPM all the candles stay lit. The internally regulated Denso alt maintains a steady 14.5 volts even at idle with everything on so in my opinion you do not need anything with more amps.
But hey it's your money shruggy What do I know after over 30 years working on Toyota cars and trucks work
Gus beer
64 Plymouth Savoy
Dana 60
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: fourgearsavoy] #2356530
08/19/17 01:02 PM
08/19/17 01:02 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
If you need more that 60 amps to keep your battery charged, it doesn't matter what someone else is running. Having 10-20 % overhead is what I'd consider a MINIMUM, otherwise you end up replacing alternators and batteries very frequently. I've seen Denso alternators fail over and over because of extra added loads. Do some careful research when you are engineering your electrical system or bad things will happen.
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: TWAMONACO] #2356582
08/19/17 02:35 PM
08/19/17 02:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
As Skeptic says, undersized alternators can be an issue. Oversized not so much. An alternator is controlled by the regulator so it will only put out enough to match demand until it hit's it's limit.
So, if you have a 120A alternator in an 80A system you'll be fine and have a 40A reserve, if you have a 60A alternator in a 80A system you will be draining your battery trying to support the load.
However, if you are going to run a 120A alternator you had best make sure your wiring and protection matches.
Don't be the exception.
Re: 60amp to 120amp Denso swap with AREngineering bracketry [Re: Supercuda] #2356841
08/19/17 10:27 PM
08/19/17 10:27 PM
Rittman Ohio
Rittman Ohio
Well I've had the same 60 amp alternator and battery in my car for over 5 years so obviously some of the above information is incorrect. I suspect the Mopar based externally regulated Denso alternator is what some of this information is based on.
Toyota has used the same basic 60 amp alternator on their vehicles with dozens of electrical systems running constantly for over 200,000 miles with the original battery and alternator. The way systems are wired with relays and carful wire selection has more to do with how many amps you need from your alternator.
Gus beer
64 Plymouth Savoy
Dana 60
