Will this piston/stroke/rod length work?
#235521
02/25/09 12:41 AM
02/25/09 12:41 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Mathematically this should work, but will the rod length be ok and not pull too much of the piston ABDC? 4.375 stroke 6.9 rod 1.621 comp height 10.725 deck height What do you think?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Will this piston/stroke/rod length work?
[Re: Sport440]
#235523
02/25/09 12:39 PM
02/25/09 12:39 PM
Von
NE Oklahoma
That will depend on the diameter of the crank counterweights and the contour of the piston skirts and thickness at the wristpin.
To the Deck the math is fine. So is my quick math to BDC. with a 7.25" crank. If things get close get the Makita, out. mike
Mike,
Thanks for your reply. If I do have clearance issues, can I turn the counterweights down and rebalance?
Seems like this combo uses 7.1 rods usually, but I already have the pistons and started
[Re: Von]
#235524
02/25/09 12:54 PM
02/25/09 12:54 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
Mike,
One thing you need to be concerned about is how far the pistons pulls out the bottom of the bore with the shorter rod .
[Re: B1MAXX]
#235526
02/25/09 01:13 PM
02/25/09 01:13 PM
Von
NE Oklahoma
I run a 4.3 stroke with a 6.7 rod. If that helps
Do you know what the diameter is of your counterweights?
[Re: B1MAXX]
#235528
02/25/09 01:16 PM
02/25/09 01:16 PM
Von
NE Oklahoma
Not off the top of my head but it is an out of the box Ohio crank.
Thanks!! I'll look it up.
[Re: AndyF]
#235532
02/25/09 01:45 PM
02/25/09 01:45 PM
Von
NE Oklahoma
You'll be fine, where did you find a 6.90 long rod? The popular rods are 6.70, 6.80 and 7.10. I've seen a couple of other lengths but never 6.90.
I was thinking I had seen a 6.9. But, I went back and looked and I was wrong. Back to the figuring.
What about 4.5 stroke with a 6.8 rod? It figures to be .054 down in the hole. Will that combo pull too much out at BDC?
[Re: JohnRR]
#235533
02/25/09 11:03 PM
02/25/09 11:03 PM
Posts: 2,009 Apollo, PA.
B1MAXX
Apollo, PA.
B or RB ???
rb
[Re: n_bogie1984]
#235535
02/25/09 11:40 PM
02/25/09 11:40 PM
Von
NE Oklahoma
I checked and the compression height is 1.633
So would 4.5 stroke, 6.8 rod, work? I come with .042 in the hole.
Would it be ok with a 7.48 counter weight? What about bdc?
[Re: n_bogie1984]
#235536
02/25/09 11:41 PM
02/25/09 11:41 PM
Von
NE Oklahoma
http://store.summitracing.com/partdetail.asp?part=ESP%2D6860C3D&autoview=sku
how about a 6.86 hemi rod will leave ya about .056 in the hole
Good idea 'cept I need a bbc width rod.
[Re: RemCharger]
#235539
02/26/09 10:06 AM
02/26/09 10:06 AM
Von
NE Oklahoma
[quoteWhy, are you using a bbc crank?
Some if not most of the aftermarket cranks are set up for a BBC rod.
